Octane booster
Old Nov 22, 2022 | 07:23 PM
Donaldbabineau's Avatar
Octane booster
I have been running 92 octane ethanol free gas in my 455, and while the car generally runs smoother at low rpms, I have noticed it knocks when I hit passing gear where 92 octane 10 percent ethanol gas does not cause this to happen. So, I tried Royal Purple octane booster since it was BOGO at O'Reilly's. I have to say the regular $15 price is steep, but the stuff works. No knocking and I never have been able to get up to 105 in 15 seconds before using it.
Old Nov 23, 2022 | 04:13 AM
BlueCalais79's Avatar
Here in SC I can get 87 Octane Ethanol Free. I will occasionally mix in some Lucas Octane Booster in my 79 Hurst Olds, and my 1994 3.4L Cutlass. They claim it will bump the number up by 3. Fair enough.
Old Nov 23, 2022 | 05:09 AM
Interesting, it shows the E10 acts as an octane booster. Of course, it has other negative side effects.
Old Nov 23, 2022 | 05:38 AM
Not really. Yes, ethanol will increase octane rating, but without knowing if the base gasoline was the same, you can't make that comparison.
Old Nov 23, 2022 | 05:40 AM
fleming442's Avatar
Mine gets faster after I change the oil or wax it, too. It's easy to just get a crap tank-full out of the pump.
The only one I have found that works is Torco. The Race Gas concentrate requires too much- 1qt to 5gal.
Old Nov 23, 2022 | 06:03 AM
Ain't it the truth!
Old Nov 23, 2022 | 07:11 AM
redoldsman's Avatar
Proud Viet Nam Veteran
If you use ceramic wax, it will run even faster.
Old Nov 23, 2022 | 07:52 AM
I've had two fill ups of 92 ethanol free gas from different stations cause knocking. I have gotten numerous fill ups with with 92 ethanol 10 percent with no knocking. I have videoed my speedometer on numerous occasions and it usually takes over 16 seconds to pass 100 based on the time signature at launch, sometimes longer, never faster. Using the same method, I was at 105 in 15 seconds after using octane boost. My speedometer is accurate based on GPS.
32redman
Sep 9, 2019 02:48 PM
sammieolds
Jan 28, 2013 06:33 AM
Demonator666
Mar 25, 2012 12:33 PM
dads66cutlass
Jul 24, 2011 10:54 AM
Ddbord
Jul 6, 2010 09:05 PM
