which brake booster?
Old Sep 9, 2019 | 07:59 AM
32redman's Avatar
What size booster did you use with tall valve covers? Single or dual diaphragm? 1.00 or 1.125 bore?
I want to change it now while I have the front clip and motor out. 72 Cutlass Post w/ 455
Thanks in advance
Old Sep 9, 2019 | 11:18 AM
Do the math. A stock booster is 11". Assuming engine vacuum is the same in all cases (which may not be the case for a modified engine that needs tall valve covers), the amount of assist you get from a booster is a direct function of the booster area. A smaller single diaphragm booster will have less assist. A 9" booster has 67% of the area (and thus 67% of the assist) of an 11" booster. A 7" booster is 41% of the 11". Obviously a smaller dual diaphragm booster is twice these numbers - 133% for the dual 9" and 81% for the dual 7". If you must have power brakes, consider a hydroboost.
As for the M/C diameter, smaller requires less pedal force but more pedal travel for the same force at the wheels. Conversely, larger requires more pedal force but less travel. I'll note that my stock 70 W-30 with manual disc brakes stops fine without excessive pedal force.
Old Sep 9, 2019 | 12:34 PM
32redman's Avatar
Thanks Joe
Old Sep 9, 2019 | 02:48 PM
70cutty's Avatar
Beer Connoisseur
Consider hydroboost, I converted mine for less than $200.
70sgeek
Brakes/Hydraulic Systems
Feb 11, 2019 01:39 PM
truckman5000
May 17, 2017 06:21 PM
Stevec
Sep 20, 2014 01:42 PM
smcurro
Oct 14, 2011 12:55 PM
plee3 64Olds
Apr 28, 2011 10:01 AM
