Gas tank question
Old May 13th, 2013, 09:25 AM
Bamfer's Avatar
Gas tank question
Any way to keep gas from spilling back out of tank after filling it up ? With the cost of gas I hate seeing the stuff end up on the ground. I usually don't fill up all the way but forgot last time. Any ideas would help. Thanks
Bamfer is offline
Old May 13th, 2013, 09:32 AM
Is your cap good? Vent lines leaking? Or did you just veerfill it, as gas expands with higher ambiant temps?
oldcutlass is online now
Old May 13th, 2013, 08:34 PM
Bamfer's Avatar
Maybe over filled it. It's coming out the filler tube when I drive around. I'll check the cap but I think it's ok.
Bamfer is offline
Old May 13th, 2013, 08:59 PM
You need a new cap - it shouldn't come out if the cap is on.
Dare I say: Duh.
MDchanic is offline
Old May 14th, 2013, 03:29 AM
Grace Stinespring-Welch's Avatar
your filler tube may have rusted through
Grace Stinespring-Welch is offline
Old May 14th, 2013, 03:57 AM
Well, if we're assuming that the OP was wrong and that his gas cap isn't leaking, then...
Hairline crack at the junction of the filler neck and the tank, at the top edge.
MDchanic is offline
Old May 14th, 2013, 07:11 AM
Bamfer's Avatar
Well those are all good ideas. I guest more information is needed. I replaced the fuel tank, sending unit and reused the filler tube off the old tank, but it was good with no leaks. The gas is coming out end past the cap. So I think I need a different cap. I'll try that first and let you know what happens.
Bamfer is offline
Old May 14th, 2013, 08:18 AM
As said earlier, make sure your vent line is good. There was another post about a clogged fuel vent line that caused the fuel to burble out of the tank.
Olds64 is offline
Old May 14th, 2013, 01:22 PM
Bamfer's Avatar
I'll for it.
Bamfer is offline
Old May 14th, 2013, 02:33 PM
Oldsdruid
rocketraider's Avatar
If you got a repro tank it may not have the proper baffles in it to prevent fuel slosh. Unfortunately only way to see is drop the tank and remove the sending unit. You may be able to run a piece of hose or something in thru the filler neck and see if it bumps against a baffle.
rocketraider is online now
Old May 15th, 2013, 09:26 AM
Bamfer's Avatar
That's is a great idea. Any Ideas if it does not have the baffles ?
Bamfer is offline
Old May 15th, 2013, 10:57 AM
uaintright's Avatar
I think the problem is stomping on the gas pedal...............But hey can anyone help but to do that.........:>)
uaintright is offline
Old May 15th, 2013, 04:09 PM
yeah, you have to bust out that rocket power occasionally
Old May 16th, 2013, 06:16 AM
Bamfer's Avatar
Well it looks like no baffles. :0
Bamfer is offline
joemo
September 21st, 2022 04:47 AM
1carsick
October 17th, 2012 09:10 AM
Texas442
January 30th, 2012 05:36 PM
OLD SKL 69
January 21st, 2008 09:51 PM
Wil Lopez
January 16th, 2008 05:24 AM
Quick Reply: Gas tank question
