Gas tank question
Old May 13, 2013 | 09:25 AM
Bamfer's Avatar
Gas tank question
Any way to keep gas from spilling back out of tank after filling it up ? With the cost of gas I hate seeing the stuff end up on the ground. I usually don't fill up all the way but forgot last time. Any ideas would help. Thanks
Old May 13, 2013 | 09:32 AM
Is your cap good? Vent lines leaking? Or did you just veerfill it, as gas expands with higher ambiant temps?
Old May 13, 2013 | 08:34 PM
Bamfer's Avatar
Maybe over filled it. It's coming out the filler tube when I drive around. I'll check the cap but I think it's ok.
Old May 13, 2013 | 08:59 PM
You need a new cap - it shouldn't come out if the cap is on.
Dare I say: Duh.
Old May 14, 2013 | 03:29 AM
Grace Stinespring-Welch's Avatar
your filler tube may have rusted through
Old May 14, 2013 | 03:57 AM
Well, if we're assuming that the OP was wrong and that his gas cap isn't leaking, then...
Hairline crack at the junction of the filler neck and the tank, at the top edge.
Old May 14, 2013 | 07:11 AM
Bamfer's Avatar
Well those are all good ideas. I guest more information is needed. I replaced the fuel tank, sending unit and reused the filler tube off the old tank, but it was good with no leaks. The gas is coming out end past the cap. So I think I need a different cap. I'll try that first and let you know what happens.
Old May 14, 2013 | 08:18 AM
As said earlier, make sure your vent line is good. There was another post about a clogged fuel vent line that caused the fuel to burble out of the tank.
Old May 14, 2013 | 01:22 PM
Bamfer's Avatar
I'll for it.
Old May 14, 2013 | 02:33 PM
rocketraider's Avatar
Oldsdruid
If you got a repro tank it may not have the proper baffles in it to prevent fuel slosh. Unfortunately only way to see is drop the tank and remove the sending unit. You may be able to run a piece of hose or something in thru the filler neck and see if it bumps against a baffle.
Old May 15, 2013 | 09:26 AM
Bamfer's Avatar
That's is a great idea. Any Ideas if it does not have the baffles ?
Old May 15, 2013 | 10:57 AM
uaintright's Avatar
I think the problem is stomping on the gas pedal...............But hey can anyone help but to do that.........:>)
Old May 15, 2013 | 04:09 PM
yeah, you have to bust out that rocket power occasionally
Old May 16, 2013 | 06:16 AM
Bamfer's Avatar
Well it looks like no baffles. :0
joemo
Sep 21, 2022 04:47 AM
1carsick
Oct 17, 2012 09:10 AM
Texas442
Jan 30, 2012 05:36 PM
OLD SKL 69
Jan 21, 2008 09:51 PM
Wil Lopez
Jan 16, 2008 05:24 AM
