Troubleshoot stall when shift from D to R
Old May 16, 2013 | 08:39 AM
Danny Boy's Avatar
1972 98 & 1984 H/O
I have an '84 H/O (307) that stalls when I shift from Drive to Reverse but only once the engine is warmed up. It also runs rough when I shift from Park to Reverse when it is warmed up. It shifts fine when engine is cold.
Vacuum line maybe?
Old May 16, 2013 | 08:59 AM
Vacuum leaks, tuneup time, crummy gas,...
Old May 16, 2013 | 09:19 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
X2 on Vac leak. If you dont find a vac leak next look at the EGR and the TVS. Check the choke pull off too.
hvysupreme
Feb 18, 2017 12:40 PM
junkyard72
Apr 3, 2013 11:16 PM
Alocatelli
Dec 10, 2012 07:49 AM
1965cutlassragtop
Jul 1, 2012 02:00 PM
