Gas tank question
Gas tank question
Any way to keep gas from spilling back out of tank after filling it up ? With the cost of gas I hate seeing the stuff end up on the ground. I usually don't fill up all the way but forgot last time. Any ideas would help. Thanks
Well those are all good ideas. I guest more information is needed. I replaced the fuel tank, sending unit and reused the filler tube off the old tank, but it was good with no leaks. The gas is coming out end past the cap. So I think I need a different cap. I'll try that first and let you know what happens.
If you got a repro tank it may not have the proper baffles in it to prevent fuel slosh. Unfortunately only way to see is drop the tank and remove the sending unit. You may be able to run a piece of hose or something in thru the filler neck and see if it bumps against a baffle.
joemo
September 21st, 2022 05:47 AM
1carsick
October 17th, 2012 10:10 AM
Texas442
January 30th, 2012 06:36 PM
Wil Lopez
January 16th, 2008 06:24 AM
