Garage Fire Alarm Detector
Old January 14th, 2024, 07:34 AM
Oldcoyote's Avatar
Normally smoke detectors are not recommended because of exhaust fumes. Heat detectors are supposed to be used.
I would like a smart (WiFi /Alexa) detector for when I am away. The only ones I see are SMOKE detectors. Do smoke detectors work "OK" in garages? I could mount it in the front of the garage, well away from the exhaust.
Oldcoyote is offline
Old January 15th, 2024, 08:49 AM
Oldcoyote's Avatar
Today, I ordered from Amazon: a heat sensor alarm and an X-sense wi-fi alarm listener. We shall see.
Old January 15th, 2024, 12:11 PM
Let us know how the install goes.
Olds64 is offline
Old January 17th, 2024, 12:56 PM
jaunty75's Avatar
Installation is one thing. How about actual functionality? Smoke detectors work so well because smoke diffuses quickly and gets to a smoke detector mounted way up high on a wall or ceiling in a matter of seconds from anywhere in the room. But a HEAT detector, I don't know. What if the fire starts on the other side of the room from where the detector is? How much burning could take place before the heat level in the location of the detector gets high enough to trigger it? I would think it could be many minutes. Maybe several heat detectors are needed placed all around the garage.
Also, how do you test a heat detector?
jaunty75 is offline
miko442
May 1st, 2023 02:28 PM
tgilligan
January 26th, 2020 10:36 AM
VikingBlue
September 2nd, 2015 05:08 AM
chasman414
January 7th, 2013 07:19 AM
thatguy32567
March 10th, 2010 05:14 PM
Quick Reply: Garage Fire Alarm Detector
