Filling heat risers and welding exhaust divider
Old Jan 4, 2013 | 02:55 PM
chasman414's Avatar
Has anyone ever filled their heat risers between 2/4 and 3/5 exhaust runners and also welded the exhaust divider between the same cylinders on the exhaust side of C heads? I am told it can add HP although I'm not sure how.I tried to search these topics here but came up with nothing!!!
Old Jan 4, 2013 | 03:01 PM
Oldsmaniac's Avatar
I have not tried blocking heat passages but heard it can be done by melting an old piston and heating the head in your oven.... As for welding the divider I had mine milled down flat so its even with the exhaust ports. Headers fit better too with that.
Old Jan 4, 2013 | 04:32 PM
VORTECPRO's Avatar
Yes, its manditory if you want to make good power.
Old Jan 4, 2013 | 05:16 PM
davebw31's Avatar
take (mill) .125" off the exhaust side of the head and you are done. Adds 8 hp on a NHRA stocker engine. More on a non-NHRA spec'd engine. It shortens the exhaust pluses. Does not effect header/stock manifold fit/clearance.
I did all of my exhaust crossover ports using one Olds piston, using a case iron skillet and a home made forge (copper tubing attached to air line from my compressor) using charcoal. Block off the exhaust crossover (intake side of head) and pored melted alumn. through chamber side.
Old Jan 4, 2013 | 06:50 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
If you’re running a cast intake?....I welded the "slugs" into my intake and left the heads alone. I’m running W Z 455 manifolds on a 68 400 with big valve C heads. I also removed the stove flap and bi-metal spring on the driver’s side mani and welded the holes. If your using an aluminum intake then you need to weld the plugs into the heads (iron heads of course). Or find someone to weld aluminum plugs into the aluminum intake.
Yes you can build the divider on the heads but you need to find a welder who knows how to weld on this metal correctly then mill it flat. I actually built up the divider on my manifolds because I didn’t want to mess with the numbers matching heads nor pull them at that time. It works but doing the heads is the better method.
I blocked off the heat riser circuit to remedy my hot starting issue. Problem solved. Cold blooded as hell due to the divorced choke but I only run in the summer.
Old Jan 4, 2013 | 07:03 PM
67 Cutlass Freak's Avatar
heat riser
http://72.22.90.30/phpBB2/viewtopic.php?t=85840
Old Jan 7, 2013 | 07:19 AM
chasman414's Avatar
Originally Posted by 67 Cutlass Freak
Thanks to all of you for the advice, I think I will try one of your methods but I,m not sure which one.
mzbk2l
Oct 15, 2025 05:52 AM
Finn5033
Oct 10, 2022 08:08 PM
odddoylerules
Mar 9, 2015 11:43 AM
73aussie455
Apr 1, 2014 04:54 PM
Nov 11, 2013 09:39 AM
