Cooling System Upgrade
I would add the 4 row radiator, 6 or 7 blade clutch fan, and if you don't have a fan shroud add that too. There was a good thread posted on this topic a year or so ago. I believe that Joe P. mentioned in some situations the fan shroud may not help but a detriment. I don't remember enough about the details to explain it. But in my part of the country for the kind of driving I do changing those items stopped my 1970 from overheating in the summertime. If you have time you might do a "search" on overheating or 4 row or 4 core and read through the posts that come up. John
congrats for correctly referring to the radiator as a 3 row, not a 3 core.
radiators have one core that can have one or more rows of cooling tubes.
The radiator a shroud is a must with the fan blades only partially into the shroud
I switched from a 5 blade flex fan to a HD 6 blade non-flex with a clutch and the summer ac, stop and go temps declined 15 - 20 degrees. much quieter also
Just be aware that the four row radiator has wider tanks than the two and three row units. You will need to get a four row top plate and the correct bottom brackets that are spot welded to the core support. Alternately, you can modify the brackets you have if you are a decent welder. Finally, you can also get an aluminum radiator that will fit your narrower brackets.
Look at your water pump if it is off the motor....There were two different size impellers and most rebuilt pumps use a cheap stamped impeller...... If you can find a pump with a large impeller and the original cast impeller I use those on my motors........
I use high performance Robertshaw thermostats and if is a totally new system then run distilled water instead of tap water with your antifreeze and then a bottle of Water Wetter.....
I use these, too. However, they are now sold under the Mr Gasket brand.
Good idea - The minerals in tap water are horrible.
I just discovered they're making a repop top plate for the 4 row! Anybody seen one in person yet? How do that compare to the original?
http://cgi.ebay.com/ebaymotors/ws/eB...NA%3AUS%3A1348
