Cooling System Upgrade
Old Dec 10, 2009 | 04:00 PM
nelsontj's Avatar
I have a 1970 Oldsmobile 442 w/455 with a 3-row radiator and 4 blade fan. I want to upgrade the cooling system. What suggestions do you have?
Old Dec 10, 2009 | 04:06 PM
mugzilla's Avatar
is Fast Enough ...
4 core or custom aluminum, find a factory fan and put a gm heavy duty clutch on it . Do you have the OAI hood? Do you have a shroud or a trans cooler ? Stock or modified engine ?
2blu442's Avatar
I would add the 4 row radiator, 6 or 7 blade clutch fan, and if you don't have a fan shroud add that too. There was a good thread posted on this topic a year or so ago. I believe that Joe P. mentioned in some situations the fan shroud may not help but a detriment. I don't remember enough about the details to explain it. But in my part of the country for the kind of driving I do changing those items stopped my 1970 from overheating in the summertime. If you have time you might do a "search" on overheating or 4 row or 4 core and read through the posts that come up. John
Old Dec 10, 2009 | 05:06 PM
nelsontj's Avatar
Answers to mugzilla: Do not have OAI, but may try that set-up next summer. The engine will remain stock. I do not currently have a fan shroud.
Old Dec 10, 2009 | 06:50 PM
Lady72nRob71's Avatar
Good suggestions so far. Remember the 'weatherstrip' that goes around the radiator and the rubber sealing flaps that go at the upper radiator (2 sides) and below at the bottom of the bumper.
Old Dec 10, 2009 | 07:21 PM
dc2x4drvr's Avatar
The 70 442 originally came with a fan shroud, that might help keep your 455 cool..
Old Dec 10, 2009 | 08:39 PM
Blk71SX's Avatar
congrats for correctly referring to the radiator as a 3 row, not a 3 core.
radiators have one core that can have one or more rows of cooling tubes.
The radiator a shroud is a must with the fan blades only partially into the shroud
I switched from a 5 blade flex fan to a HD 6 blade non-flex with a clutch and the summer ac, stop and go temps declined 15 - 20 degrees. much quieter also
Old Dec 11, 2009 | 03:15 AM
Yellowstatue's Avatar
Smile Big jugs
And don't forget the coolant recovery container... Ask Mugz
Old Dec 11, 2009 | 06:38 AM
Just be aware that the four row radiator has wider tanks than the two and three row units. You will need to get a four row top plate and the correct bottom brackets that are spot welded to the core support. Alternately, you can modify the brackets you have if you are a decent welder. Finally, you can also get an aluminum radiator that will fit your narrower brackets.
Old Dec 11, 2009 | 06:40 AM
You might consider an electric fan. You can get them cheap from the salvage yard off of a full sized truck or van.
Old Dec 11, 2009 | 09:23 AM
Bobsw32's Avatar
BobsW32
Look at your water pump if it is off the motor....There were two different size impellers and most rebuilt pumps use a cheap stamped impeller...... If you can find a pump with a large impeller and the original cast impeller I use those on my motors........
I use high performance Robertshaw thermostats and if is a totally new system then run distilled water instead of tap water with your antifreeze and then a bottle of Water Wetter.....
Old Dec 11, 2009 | 03:40 PM
mugzilla's Avatar
is Fast Enough ...
I run brita filter water in a humidifier and filters in it last longer ...
Old Dec 11, 2009 | 07:13 PM
I use high performance Robertshaw thermostats .....
I use these, too. However, they are now sold under the Mr Gasket brand.
Good idea - The minerals in tap water are horrible.
Old Dec 11, 2009 | 08:53 PM
mugzilla's Avatar
is Fast Enough ...
Expansion Tank ..?
Old Dec 12, 2009 | 03:26 AM
Jugs!!
Old Dec 12, 2009 | 07:05 AM
Bottles!
Jugs have handles on 'em...
Old Dec 12, 2009 | 07:46 AM
2blu442's Avatar
I just discovered they're making a repop top plate for the 4 row! Anybody seen one in person yet? How do that compare to the original?
http://cgi.ebay.com/ebaymotors/ws/eB...NA%3AUS%3A1348
Dave Siltman
Mar 23, 2012 09:24 AM
jaunty75
May 28, 2011 12:14 AM
henryk8398
Aug 18, 2010 06:06 AM
radioburningchrome
Aug 10, 2010 06:52 PM
jeffreyalman
Jun 7, 2009 04:49 AM
