1957 Olds Pedal question
Old March 2nd, 2013, 06:32 PM
Charly9g's Avatar
Hi All. Am totally (or trying) to upgrade a '57 olds 88 to disc brakes. Has anyone here done this and what kind of Brake pedal system should I use or how can I alter mine to work w/a firewall mounted master cilandir (spelling) ,sorry. Any advice about anything involved w/this transform would be greatly appreciated. many thanks. Charly9g. WFG4U@aol.com
Charly9g is offline
Old March 2nd, 2013, 06:33 PM
Charly9g's Avatar
Cylindir
Charly9g is offline
Old March 2nd, 2013, 07:06 PM
2blu442's Avatar
Welcome to the site!
Pat (citcapp) has done this on his 1957. If he doesn't see and reply to this thread you might send him a PM or email. Here's a thread where he's referenced the swap.
https://classicoldsmobile.com/forums...ldsmobile.html
John
2blu442 is offline
Old March 2nd, 2013, 07:10 PM
citcapp's Avatar
I did the same swap on my 57
Used an aftermarket firewall mounted 8" dual diaphragm booster with a corvette master cylinder.
Did away with the drivers side air box (heat and defrost work fine without it).
fabricated a blank flat plate out of 16 gauge steel to cover the air box hole.
Used a swinging pedal and bracket out of a 70 Olds delta 88 out of the wrecking yard mounted it to the left of the steering column. heated up the swing arm and bent it to fit to the right side brake location. Did the conversion in a weekend.
Almost forgot ran a brace from the pedal bracket to the steering column dash support to add strength to the pedal assembly
I am sure there are several brake pedals and bracket that can be made to fit just have to cruise the wrecking yards.
citcapp is offline
Old March 3rd, 2013, 02:52 PM
Charly9g's Avatar
'57 Olds Pedal Assembly
Pat (Citcapp). Many thanks for the reply re: '57 olds pedal assembly. That will help me out a "Bunch"! Might have more questions when I start the conversion. Hope you don't mind. thanks again, Bill (Charly9g).
Charly9g is offline
Old March 6th, 2013, 02:49 PM
NGABronco's Avatar
I printed out Citcapp's photos, I showed them to my helpers and it was like
"Oh Yeah"!!! They could not figure out what I was trying to do until they saw the pics!!! Good write-up!!!
NGABronco is offline
Old March 6th, 2013, 04:20 PM
citcapp's Avatar
Thanks for the compliment Good luck with your project
citcapp is offline
67Rocket
August 3rd, 2015 11:49 AM
rcdynamic88
Brakes/Hydraulic Systems
August 6th, 2014 07:41 PM
TripDeuces
September 9th, 2010 04:49 AM
47 Convertible
July 14th, 2010 11:39 PM
KQQLCAT
April 29th, 2009 05:51 AM
Quick Reply: 1957 Olds Pedal question
