Brake Pedal Push Rod Mounting Hole Question
Old Aug 4, 2014 | 10:42 PM
rcdynamic88's Avatar
I have changed from the stock 1965 Olds Cutlass Power Drum/Drum brake set up to one of the 64-72 front disc conversions. I didn't want to run a power brake booster so I went with a manual disc/drum Master Cylinder and proportioning valve (from Right Stuff Detailing). I am having a problem getting the brakes to apply fully. The pedal isn't soft or spongy, I just don't seem to making enough pressure. I have seen some posts on here that mention different mounting holes for the brake pedal push rod. I have the rod currently in the lower (closest to to floor) hole on the brake pedal "arm". I thought it looked as if I would get more pedal stoke if I used that hole. Is that the correct hole for the rod with manual brakes? What are some other things to look at when it feels like you have a good hard brake pedal, but the brakes won't "lock up" at all when you nail them like in a panic stop.
Old Aug 6, 2014 | 05:41 PM
Well, 50-50 chance of getting it wrong.
Manual brakes use the upper hole, since you want more leverage at the pedal. Power brakes use the lower hole since you don't need the leverage.
Old Aug 6, 2014 | 07:41 PM
Thanks Joe! On a 50/50 chance, I instinctively get it wrong 100% of the time I actually found one of your previous answers to this very question after I posted this thread. I should of used the "search" function. At any rate, I moved the rod to the upper hole (it had plenty of adjustment threads left to get the length just right). I enlisted my oldest son to do the "pump-em-up" bleeding routine while I ran around to each wheel. I now have manual brakes that will stop you so suddenly you had better be prepared for it! Thanks again for sharing the stuff you know on this forum.
68f8t5
Jun 21, 2015 06:13 AM
Rocket North
May 7, 2014 07:11 AM
RAMBOW
Aug 18, 2012 12:00 PM
ggriffin1960
Jan 31, 2012 10:20 AM
70convert
May 2, 2011 06:04 AM
