1957 Olds Pedal question
Old Mar 2, 2013 | 06:32 PM
Charly9g's Avatar
Hi All. Am totally (or trying) to upgrade a '57 olds 88 to disc brakes. Has anyone here done this and what kind of Brake pedal system should I use or how can I alter mine to work w/a firewall mounted master cilandir (spelling) ,sorry. Any advice about anything involved w/this transform would be greatly appreciated. many thanks. Charly9g. WFG4U@aol.com
Old Mar 2, 2013 | 06:33 PM
Charly9g's Avatar
Cylindir
Old Mar 2, 2013 | 07:06 PM
2blu442's Avatar
Welcome to the site!
Pat (citcapp) has done this on his 1957. If he doesn't see and reply to this thread you might send him a PM or email. Here's a thread where he's referenced the swap.
https://classicoldsmobile.com/forums...ldsmobile.html
John
Old Mar 2, 2013 | 07:10 PM
citcapp's Avatar
I did the same swap on my 57
Used an aftermarket firewall mounted 8" dual diaphragm booster with a corvette master cylinder.
Did away with the drivers side air box (heat and defrost work fine without it).
fabricated a blank flat plate out of 16 gauge steel to cover the air box hole.
Used a swinging pedal and bracket out of a 70 Olds delta 88 out of the wrecking yard mounted it to the left of the steering column. heated up the swing arm and bent it to fit to the right side brake location. Did the conversion in a weekend.
Almost forgot ran a brace from the pedal bracket to the steering column dash support to add strength to the pedal assembly
I am sure there are several brake pedals and bracket that can be made to fit just have to cruise the wrecking yards.
Old Mar 3, 2013 | 02:52 PM
Charly9g's Avatar
'57 Olds Pedal Assembly
Pat (Citcapp). Many thanks for the reply re: '57 olds pedal assembly. That will help me out a "Bunch"! Might have more questions when I start the conversion. Hope you don't mind. thanks again, Bill (Charly9g).
Old Mar 6, 2013 | 02:49 PM
NGABronco's Avatar
I printed out Citcapp's photos, I showed them to my helpers and it was like
"Oh Yeah"!!! They could not figure out what I was trying to do until they saw the pics!!! Good write-up!!!
Old Mar 6, 2013 | 04:20 PM
citcapp's Avatar
Thanks for the compliment Good luck with your project
67Rocket
Aug 3, 2015 11:49 AM
rcdynamic88
Brakes/Hydraulic Systems
Aug 6, 2014 07:41 PM
TripDeuces
Sep 9, 2010 04:49 AM
47 Convertible
Jul 14, 2010 11:39 PM
KQQLCAT
Apr 29, 2009 05:51 AM
