some advice on a 455 build
Old Jan 3, 2014 | 10:58 PM
orismedic's Avatar
So I am slowly working on my 71 cutlass and it is about time to start thinking about the engine. I have a 350 2bbl right now with a th350. I would like to put a 455 with around 500hp that will work with an OAI hood. a beefed up 200r4(CK has a nice one), with 3.73 posi rear end and 28 inch tires. this is going to be mostly a street car but I like to play too. and I will take to the track a few times too. I do have a holly street dominator intake but I'm not attached to it. and I would like to keep the compression around 10-1. ( I would like to still be able to use pump gas). I was thinking about 77cc aluminum heads with -22 dish pistons. any way kind of just in the planning stages so any advice would be good.
Old Jan 4, 2014 | 05:59 AM
cutlassefi's Avatar
Do a search but here are the basics for what you'll need to make 500hp at the crank.
Good machine work
Forged piston, i.e. Wiseco or Icon, 15cc dish
Eagle H beam rods
Edelbrock heads
Your Holley Street dominator will be fine.
I'd do a Quick Fuel 830 carb
Cam in the 240@.050 range, preferably a roller.
1 7/8 headers
That should do it. Check out some of my builds etc on here. That should give you a bit more info.
Old Jan 4, 2014 | 12:31 PM
orismedic's Avatar
Thanks that helps a lot. Gives me a please to start. And I will check out your builds.
Old Jan 5, 2014 | 07:05 AM
orismedic's Avatar
EFI are you talking some thing like comp cams 42-433-9 roller cam?
Old Jan 5, 2014 | 08:17 AM
cutlassefi's Avatar
No, with good heads that cam doesn't have enough lift in it to use them. I'd do something with more lift and on a 112 lobe sep, not a 110.
Old Jan 20, 2014 | 02:52 PM
orismedic's Avatar
EFI just want you to know I think you are the man, and down the road I will probably come to you for my cam. I on another note Im wondering if 60 over is to much for a 455, would this make the walls to thin?
Old Jan 20, 2014 | 03:03 PM
Mr Nick's Avatar
Mark's a good guy to work with, I got my roller cam & lifters from him for my SBO. Would buy from him again for sure.
Old Jan 20, 2014 | 03:07 PM
cutlassefi's Avatar
Not normally. But I'd have them checked.
Thanks Nick, I appreciate the kind words.
Old Jan 20, 2014 | 03:26 PM
orismedic's Avatar
thanks for the info
AK71CutlassS
May 14, 2014 08:00 PM
EightballZ
Dec 1, 2013 03:58 PM
EightballZ
Nov 5, 2013 05:56 AM
wildwillie1981
Apr 24, 2013 04:19 PM
TORTUS
Oct 18, 2012 04:50 AM
