Need Advice on 455 Build
Old May 6, 2014 | 06:39 PM
AK71CutlassS's Avatar
I have My block, crank, and connecting rods at a local machine shop in Alaska. the 455 will probably have to be bored over .060. Looking for Advice on making 450-500 horses . Want a Streetable ride. I pulled it out of a parts car. it had a cn crank in it.
Need advice on the process/order at machine shop and parts as well. Thanks in Advance
Tony
Old May 6, 2014 | 07:08 PM
Talking
5-6k budget. Cutlassefi I hear you know your olds engines????
Old May 6, 2014 | 09:42 PM
2blu442's Avatar
Welcome to the site Tony. Sorry, I don't have any suggestions about your 455 build, but I know there's several members here who have done what you want to do.
If you don't get a reply read through some of the build threads and maybe send a PM to some of the guys who have built engines like you want.
John
Old May 6, 2014 | 09:57 PM
Thanks for the Welcome to the site. Yeah ive sent cutlassefi a PM. Ill wait for reply. Glad to be on the forum
TONY
Old May 7, 2014 | 06:02 PM
cutlassefi's Avatar
Answered your pm, thanks!
Old May 11, 2014 | 04:21 PM
Smitty275's Avatar
Engine Builder
Have your pistons before you have the block bored. That way they can get the right piston to wall clearance.
Have your rods resized with new bolts and sized to factory minimum spec. I always have a line hone performed on the mains so I know they are straight. Once again stay to factory minimum spec. Once all block work is complete give the machine shop the rod & main bearings to put in the resized rods and main saddle so they can mic for actual size. Then grind the crank for desired clearance. Personally I set the BBO up at .0022 to .0025 on both rods and mains. Never had an issue with this clearance set up.
Old May 11, 2014 | 04:51 PM
cutlassefi's Avatar
X2 on everything except the rods. Don't waste your time on the stock stuff, they suck. Buy the Eagles, they're much stronger and even lighter. Go figure.
Old May 13, 2014 | 08:51 PM
Just Ordered EAGLE Connecting Rods. got em for 440$ SHipped. Waiting to hear back from machine shop on what Cylinders will be bored to . Getting Antsy
Old May 14, 2014 | 08:00 PM
Just heard back from Machine shop. Is there any Wiesco Kits that have .060 Pro TRU Pistons and .030 Rod Bearings and .020 Mains??
orismedic
Jan 20, 2014 03:26 PM
EightballZ
Dec 1, 2013 03:58 PM
EightballZ
Nov 5, 2013 05:56 AM
wildwillie1981
Apr 24, 2013 04:19 PM
TORTUS
Oct 18, 2012 04:50 AM
