Hawards Roller Cam
Old Oct 4, 2012 | 10:29 AM
SRV8's Avatar
Hawards Roller Cam
Hi,
I'm just making up my mind which cam I should use,
has someone experience with Howards Roller cams.
Engine will get EDL-heads and later FAST EZ EFI, but now 800-carb.
Have already performer intake.
I want to have 3,70 gears in the back, 295/60 r15 tires, need PB and later TKO-600. I've now TH400.
Should be fore street use Stop sign racing ;-) but will be driven on strip 4-5 per year.
I want to shift between 5600-5800 rpm and have as much as possible of torque.
What do you think about this 2 Howards cams, will use them with the Howards roller lifter, are they to radical for the street ?
514825-10 NA 278 282 225 229 .560 .555 110 106 Hyd. Hyd. 1,4
1800-5600 Fair idle, Performance Street, broad usable power range.
514155-10 NA 286 286 233 233 .549 .549 110 106 Hyd. Hyd. 1,4
2000-5800 Choppy idle, strong low & mid range performance. 2500+ stall.
Old Oct 4, 2012 | 10:52 AM
dancutlass's Avatar
I'd really recommend to contact Mark (cutlassefi), with your build specs and ask him which cam would be the best for your build! He has already offered you help in your first thread!
Old Oct 4, 2012 | 01:00 PM
SRV8's Avatar
Hi Dancutlass,
I'm in contact with cutlassefi, he is a very very helpful person.
I only want to make up my mind and hear some other opinions.
Because I don't really know how much hp vs. torque I need for the street.
Sometimes less is more ;-)
Old Oct 4, 2012 | 01:11 PM
dancutlass's Avatar
Originally Posted by SRV8
Hi Dancutlass,
Fine you are in good hands then
I think it's not a question of what you "need" for the street, it's just a question of what you want^^
And what the TÜV says...have you thought about that already??
Old Oct 12, 2012 | 02:28 AM
SRV8's Avatar
Hi any opinions ?
Old Oct 12, 2012 | 08:14 AM
coppercutlass's Avatar
Chevy budget Olds powered
im running a howards flat tappet hyd. cam. yet to break in and run it in the engine. I have always ran comp cams but with this build i wanted to do something diffrent. I havehad alot of friends run howards cams but they usually custom ordered i bought mine off their catalog.
Old Oct 13, 2012 | 11:19 PM
SBORule's Avatar
All I can say is Horward Cams has been around since the stone age.
You give some good information about your combo & goals but it's too incomplete and then combo changes, so I wouldn't even try to give you any cam recommendations.
Call Crane Cams and CompCams tech line and see what they suggest.
I'm not a BIG hydraulic roller fan, I like flat tappet cams.
oldzy
Jul 29, 2011 12:24 AM
fly1
Dec 8, 2010 07:07 PM
442garage
Oct 20, 2008 10:25 AM
Redog
Aug 14, 2008 06:56 PM
72RocketPower
Aug 11, 2005 04:51 AM
