455 E heads setup
455 E heads setup
I am going through a good running 455 that I tore down to fix a few things - cam change (back to stock), oil pan replacement (changing from deep Moroso pan back to stock), and replacing torque converter (changing from high stall back to stock).
Previous owner has double valve springs and white Teflon positive valve seals on machined .495 guides. I think I'll ditch the double springs, don't think a big motor that never sees 4000 rpm needs them? And going back to umbrella seals - good idea? I've heard the positive seals don't let enough oil to the stems, opinions?
PC style seals work just fine.
And you really need to check spring pressure before you change them out. I’ve seen double springs have LESS pressure than some singles.
Could be the retainers also. A lot of aftermarket retainers give you more installed hgt than factory. Nd like Mark said before you waste money on springs I would take yours to someone who can check the seat and open pressures. They might be just fine the way they are.
Further checking - I have some specs on the double springs and a set of BBC springs I have
Double spring on the heads now
120 lbs seat pressure @ 1.880" installed ht
280 lbs open pressure @ 1.380"
Single BBC spring
80 lbs seat pressure @ 1.880" installed ht
250 lbs open pressure @ 1.380"
Which set would you run?
Single BBC spring
Single BBC spring
Single BBC spring
are the valve guides replacement bronze or stock iron?
