My 67 Idle with 455
Old Nov 25, 2023 | 04:02 PM
oldsrush's Avatar
Gearhead
My 67 Idle with 455
Is this a stock cam? It's a 70 model 455
Old Nov 25, 2023 | 04:04 PM
Your video has a problem.
Old Nov 25, 2023 | 04:10 PM
oldsrush's Avatar
Gearhead
It works for me
Old Nov 25, 2023 | 04:11 PM
Well, that makes one of us.
Old Nov 25, 2023 | 04:26 PM
66SportCoupe's Avatar
It sounds like it has an aftermarket cam in it.
Old Nov 25, 2023 | 04:50 PM
oldsrush's Avatar
Gearhead
I forgot to make public, does it work for you now?
Old Nov 25, 2023 | 05:22 PM
Works for me. Nice sounding. Generally, if you hook up a vacuum gauge to the stock engine/cam, you'll expect a vacuum of ~18"Hg. Aftermarket cam (generally) would drop your vacuum down below 15"Hg.
Old Nov 25, 2023 | 05:47 PM
Sounds like it has a cam.
Old Nov 25, 2023 | 06:54 PM
65B01Delta's Avatar
Sounds Good.
Old Nov 25, 2023 | 07:14 PM
Maybe just me, but the idle sounds a little fast to me. If the idle is a little fast, it makes it a little more difficult to judge how much cam you have in it? Conversely, if you have purposely set the idle that high just to keep it from stalling, you probably have an aftermarket in it. Just my two cents.
Old Nov 25, 2023 | 07:43 PM
69CSHC's Avatar
Sounds like a more aggressive aftermarket cam to me.
I've owned a 66 442 with its original 400 and 71 98 with its original 455. Both engines were stock, the 442 had Flowmasters and the 98 was factory exhaust. Neither sounded anything like yours.
Old Nov 26, 2023 | 07:37 AM
oldsrush's Avatar
Gearhead
I was thinking maybe a W30 cam. But it does have lower than stock vacuum, 14-15 inches at idle. Looking forward before too long installing my new Lunati VooDoo hydraulic roller cam 221/229 549/565 112 LSA on a 106 ICL. Got one more car show to attend before tear down.
Old Nov 26, 2023 | 09:24 AM
Okay, heard it. Sounds good -- how does it go?
Old Nov 26, 2023 | 09:55 AM
fleming442's Avatar
Idle is a touch high as mentioned. Also, the vacuum gauge will tell more. Sounds good 👍
Old Nov 26, 2023 | 01:21 PM
oldsrush's Avatar
Gearhead
It has decent power but off a little from what I think it should have. I'm blaming the J heads on it for that. I have a brand new set of Edelbrocks going on it with the cam change which should bring it up to par.
Old Nov 26, 2023 | 02:05 PM
Are the duration #'s at .050?
Old Nov 26, 2023 | 02:34 PM
If they're not, then that cam is significantly milder than factory.
These days "advertised" duration is pretty much a thing of the past. Any reputable grinder posts their figures @ 0.050.
Old Nov 26, 2023 | 02:37 PM
Maybe a combination of too much cam and not enough compression?
Sure does sound cool, though.
Old Nov 26, 2023 | 02:45 PM
oldsrush's Avatar
Gearhead
Yes, and if I remember correctly are close to your cam numbers. Your LSA was 110?
Old Nov 26, 2023 | 03:18 PM
You have a good memory, my cam does have a 110 LSA, 226/230 duration at .050, and 496/512 Lift. For the benefit of those following, my cam numbers are in a '67 400ci E block, C heads, with the heads professionally ported/polished.
Old Nov 26, 2023 | 03:51 PM
fleming442's Avatar
Oofa. Been there; done that
Clark455
May 30, 2023 12:12 AM
New2oldsw30
Jul 17, 2022 05:51 AM
big man
Jul 13, 2021 10:25 AM
generalmopars
Sep 2, 2019 02:57 PM
67Olds442X2
Oct 22, 2011 12:00 PM
