455 E heads setup
Old Nov 18, 2023 | 12:08 PM
PaulWinn's Avatar
455 E heads setup
I am going through a good running 455 that I tore down to fix a few things - cam change (back to stock), oil pan replacement (changing from deep Moroso pan back to stock), and replacing torque converter (changing from high stall back to stock).
Previous owner has double valve springs and white Teflon positive valve seals on machined .495 guides. I think I'll ditch the double springs, don't think a big motor that never sees 4000 rpm needs them? And going back to umbrella seals - good idea? I've heard the positive seals don't let enough oil to the stems, opinions?
Old Nov 18, 2023 | 01:28 PM
cutlassefi's Avatar
PC style seals work just fine.
And you really need to check spring pressure before you change them out. I’ve seen double springs have LESS pressure than some singles.
Old Nov 18, 2023 | 01:56 PM
My engine has what look like “double springs” but are really factory rate single springs with a damper.
Old Nov 19, 2023 | 11:28 AM
PaulWinn's Avatar
Further checking - my spring pockets are 1.500 and the installed height is 1.880". Are those numbers the same as big block Chevy? I'm having trouble finding single BBO valve springs online
Old Nov 19, 2023 | 02:19 PM
cutlassefi's Avatar
I can supply springs, but are you sure about that installed height?
Old Nov 19, 2023 | 02:56 PM
PaulWinn's Avatar
Yes, exactly 1.880". PO had a single .010 shim under each but measuring without the shim I get 1.880 - why do you ask - is this an unusual number? I could have non std valve lengths or sunken seats
Old Nov 19, 2023 | 04:40 PM
BillK's Avatar
Could be the retainers also. A lot of aftermarket retainers give you more installed hgt than factory. Nd like Mark said before you waste money on springs I would take yours to someone who can check the seat and open pressures. They might be just fine the way they are.
Old Nov 23, 2023 | 09:44 AM
PaulWinn's Avatar
Further checking - I have some specs on the double springs and a set of BBC springs I have
Double spring on the heads now
120 lbs seat pressure @ 1.880" installed ht
280 lbs open pressure @ 1.380"
Single BBC spring
80 lbs seat pressure @ 1.880" installed ht
250 lbs open pressure @ 1.380"
Which set would you run?
Old Nov 23, 2023 | 12:08 PM
CANADIANOLDS's Avatar
Single BBC spring
if you’re going back to a stock cam/lift you won’t have either of those open pressures. what’s the cam specs and lift?
are the valve guides replacement bronze or stock iron?
Old Nov 23, 2023 | 05:08 PM
PaulWinn's Avatar
Cam is Mondello 20-22 with .496"/.520"
guides are stock and have been cut down for pc seals
Old Nov 23, 2023 | 05:19 PM
cutlassefi's Avatar
Then you’ll see in or about those spring pressures. But you need to know where bind is as well. If they’re ok on bind then I’d use the 120/280 spring package.
Old Nov 24, 2023 | 08:17 PM
that’s what you meant you you said you’re going back to stock?
then go with the higher poundage springs
Old Nov 25, 2023 | 02:30 PM
PaulWinn's Avatar
Oops I grabbed the wrong cam specs - will have to research a bit
Old Nov 25, 2023 | 03:11 PM
OLDSter Ralph's Avatar
Either way, 80# on the seat is to little.
71OldscutlassS
Oct 8, 2023 05:51 AM
Kapos79kutlass
Jun 5, 2023 04:13 PM
McIntosh
Jun 5, 2021 05:15 PM
1973olds98
Mar 10, 2018 12:21 PM
Casa
May 28, 2010 05:34 AM
