4 speed dual gate in 72 442
Old May 15, 2022 | 08:01 PM
drolds2u's Avatar
has anyone who changed to a 200r4 transmission fitted their car with the 4 speed automatic dual gate shifter, or did they go with the original shifter modified to work with the 200r4 ??
Old May 15, 2022 | 11:23 PM
A member of our chapter used the Shiftworks kit on a factory dual gate in a 1972 Supreme convertible with a 200-4R. Let's just say that this particular kit is not optimum. The problem is that you are stuck with the physical design of the original dual gate shifter. To get four speeds, OD (fourth) ends up in the former Neutral position, and Neutral, Reverse, and Park are all crammed into the remaining space between R and P. The resulting shifter doesn't really have a great feel, in my opinion.
Old May 16, 2022 | 05:27 AM
drolds2u's Avatar
so Joe your saying i should try to get the 4 speed dualgate to work ??
Old May 16, 2022 | 05:56 AM
What I'm saying is that the Shiftworks kit to convert the factory three speed dual gate to work with a four speed is pretty sketchy, in my opinion. The Hurst aftermarket four speed dual gate was designed for the F-body console and requires a lot of work to put it into a 70-72 console; it probably requires a custom-machined top plate. Of course, those four speed dual gate shifters are long out of production, so the ones that come up for sale have stupid-money prices (like $599 the last time I saw one on ebay). Your call.
Old May 16, 2022 | 06:22 AM
drolds2u's Avatar
do you think the 4 speed is worth a try, i have 2 of them
Old May 16, 2022 | 06:26 AM
I have no idea of your fabrication skills or wallet size. It's a better shifter, that's for sure.
Old May 16, 2022 | 01:05 PM
We have a member here who makes a detent plate that will convert a regular 3 speed shifter to a 4 speed "slap shifter". Then you can use the ShiftWorks 4 speed conversion bezel to make it look like a factory 4 speed setup.
https://classicoldsmobile.com/forums...ilable-157347/
Old May 16, 2022 | 05:16 PM
bccan's Avatar
I briefly outlined some points in this thread regarding the OD Dual Gate. If any questions, I can try to test my goldfish memory capacity in hopes of helping. Perfectly happy to pull up trim plates if you need pics.
https://classicoldsmobile.com/forums...r4-kit-163901/
Hoffa65
Jan 12, 2019 03:29 AM
Gary M
Aug 22, 2017 06:44 PM
cwracer
Apr 12, 2013 10:40 AM
AGK
May 23, 2012 07:13 PM
skryla
Mar 2, 2011 08:01 AM
