79 HO 3 speed dual gate to 4 speed dual gate conversion
Old Jan 10, 2019 | 12:04 PM
Hoffa65's Avatar
Before
Install complete ��
I removed the shifter plate (among other things) from a 4 speed dual gate shifter for an 80's Fbody and transplanted it onto a 79 HO 3 speed dual gate shifter. I cut down the Fbody 4 speed top plate so it inlays in the HO top plate.
Turned out quite nice. Almost OEM looking lol
I Have a little cleanup to do yet but for the most part its done.
Top plate cleaned up and ready to go
Old Jan 10, 2019 | 12:54 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
How does the 4 spd version function? What car and drivetrain is this on?
Old Jan 10, 2019 | 01:05 PM
Very nicely done. Unfortunately, even the F-body four speed dual gates are hard to find these days.
Old Jan 10, 2019 | 01:47 PM
Hoffa65's Avatar
The 4 speed fuctions the same as the 3 speed does, just has an extra gate for 4th.
this particular one (I have enough parts to make 2 more) is going in my 85 cutlass salon. 350 Olds with a 200R4 trans.
Old Jan 10, 2019 | 01:53 PM
Hoffa65's Avatar
Thanks Joe.
i picked 2 fbody shifter up a long time ago for a premium price. I guy on ebay has them for $500 now while the parts supply lasts.
this should be able to be done on the late 60's and early 70 shifters, the main shifter frame is the same and the 4 speed gate should bolt in like this one did.
Old Jan 10, 2019 | 01:58 PM
Originally Posted by Hoffa65
Thanks Joe.
I've been tracking the ones on ebay. I'll probably have to break down and get one soon.
A friend of mine installed the Shiftworks kit in his three speed dual gate in a 72 Cutlass. That is a very unsatisfactory solution. The kit does not change the top plate or gate. OD ends up in the former neutral position and neutral and reverse are crammed into the space between that and park. I was underwhelmed. Yours is the right way to do it. I had previously seen a similar conversion at the Pismo Beach show several years ago.
Old Jan 10, 2019 | 02:31 PM
Hoffa65's Avatar
Damn I thought I was breaking new ground lol
Old Jan 10, 2019 | 07:06 PM
RetroRanger's Avatar
72 Olds CS
looks good nice work thanks for sharing
Old Jan 11, 2019 | 02:48 PM
w-30dreamin's Avatar
71 & 72,now I want a 68
Very nice conversion
Old Jan 12, 2019 | 03:29 AM
bccan's Avatar
I have a 4 spd DG in my ‘70, takes some work to make it mount properly & play nice w/ console but worth it. IIRC I ended up using the Shiftworks cable. I have a 70 top plate/lens on it. Kid’s red car has 200-4R w/ “normal” 3 spd DG, 70 top plate/lens & shiftworks cable. Cable is a bit stiff & IIRC you can’t pull it into L1 but quite usable. Shiftworks lens is useless.
Mike Z
Mar 22, 2019 02:52 PM
Mikel7099
Oct 20, 2013 07:51 AM
cwracer
Apr 12, 2013 10:40 AM
skryla
Mar 2, 2011 08:01 AM
ScottMHoffman
Apr 20, 2009 08:05 AM
