Click Here
How do I?...
Old Nov 6, 2018 | 06:22 PM
72455's Avatar
1972 U code Supreme
How do I?...
One of my upcoming projects is to paint the bumper jack for my 72 Supreme and display it in the trunk with the spare tire mounted on an original SSII wheel. If I understand correctly, the base of the jack is used to hold the wheel tight in the trunk. My question is, do I take the center cap out of the wheel? It doesn't make sense, but I figured I would ask.
Thanks,
Dave
Old Nov 6, 2018 | 06:52 PM
rcorrigan5's Avatar
Randy C.
For the Super Stock wheels, the retaining rod comes up through one of the lug holes on the wheel and is held in place by a retaining hex nut. This nut is available through Fusick. The center cap stays on the wheel. The other jack parts are contained under the wheel with the exception of the lug wrench. It is held in place aft of the spare tire in the trunk by two lug wrench clips. Those clips are also available through Fusick.
Randy C.
Old Nov 7, 2018 | 07:36 AM
And yes, this applies to SSII wheels in addition to the pictured SSI wheel.
The special nut is available from the repro houses.
craig442
Wheels and Tires
Jul 5, 2019 02:24 PM
The Bug Man
May 4, 2017 07:49 AM
tkw31
May 18, 2016 07:51 AM
ezman604
Sep 24, 2015 12:47 PM
ToroToro
Jul 11, 2012 07:37 PM
