Suggestion for disc brake kit 1964 Vista
Old Apr 24, 2024 | 08:55 PM
mathon's Avatar
1964vistacruiserwagon
I have a 98% original and stock 1964 vista cruiser with drum brakes and 15 inch wheels. Would like to upgrade to a "plain jane" power front disc brake system. Keeping the rear brakes as they are-totally stock. Not interested in drop spindles or suspension mods. Not going to drive it over 65. Any recommended kits?
Old Apr 24, 2024 | 09:22 PM
A rebuilt and optimized factory drum setup is often superior to aftermarket discs done on the cheap.
Old Apr 25, 2024 | 04:48 AM
I don't know if they offered OE discs in 64 on the Cutlass, or if later model kits will work. If so, using OE parts would be the way to go.
Old Apr 25, 2024 | 05:00 AM
Originally Posted by Olds64
I don't know if they offered OE discs in 64 on the Cutlass ...
No, not until '67 and then it would be the complex 4-piston caliper system. I would go with a '69 or later single-piston setup.
But first, I would ask myself some hard questions about my intended use for the car. OP states that it won't see over 65 MPH, which tells me that the factory drums would be just fine as long as they are in good working order.
Old Apr 25, 2024 | 06:10 AM
The 1969-72 factory single piston caliper disc setup bolts to any 1964-72 A-body car. Use those. Note that if you are reusing the steering arms, the early cars used smaller bolts holding the steering arm to the spindle, so you will need to open those holes up. Original 1964 wheels will not clear the factory brakes. You need disc brake wheels, as used on the 67-up cars. Yes, 14" are available.
Old Apr 25, 2024 | 09:17 AM
mathon's Avatar
Thanks for the info!
Rob64cutlass
Brakes/Hydraulic Systems
29
Apr 1, 2022 05:46 AM
Dean Eechaute
Nov 3, 2021 07:19 PM
mortgagepro
Sep 3, 2021 08:12 PM
Wedgewood Rod Shop
Jan 10, 2015 08:38 AM
wiseguy58
Feb 11, 2010 01:34 PM
