Disassemble trunk mechanism on 41
Old May 6th, 2013, 05:22 PM
deaddds's Avatar
Uncle! I cannot figure out how the handle comes apart from the stupid latch mechanism to be able to pull the assembly apart. It wiggles and waggles but will not slide apart. I dont see anything in the GM manual explaining how to do this. I do not have a key so I hope that is not the reason, gulp. Advise? Thanks Pat
deaddds is offline
Old May 7th, 2013, 09:42 PM
deaddds's Avatar
Anybody have this hassle? Hate to cut up the deck lid as its solid but I will to get the part off for a guy in England.
deaddds is offline
Old May 8th, 2013, 12:39 PM
Tedd Thompson's Avatar
Funny I thought someone on this forum would know your fix. Have you tried the AACA forum both Olds, Buick and even Pontiac forums, not as active as here (except Buick) but very knowledgeable people there and they like the old stuff..... Tedd
Tedd Thompson is offline
Old May 8th, 2013, 09:10 PM
deaddds's Avatar
Thanks, Ill try there.
deaddds is offline
Old May 10th, 2013, 06:21 PM
deaddds's Avatar
FYI update to anyone in this hassle, you NEED the key or a good locksmith. After killing another hour plus messing with it I tore the car apart and found 3 keys. Ignition, door and trunk. Naturally they dont interchange so dont loose them! Once keyed in it was all of 5 seconds to disengage the 2 parts and done.
deaddds is offline
JimpeBoy
June 30th, 2015 10:01 AM
Prophe'c
October 9th, 2010 03:12 PM
bbg2d
March 1st, 2010 02:27 PM
Eightupman
August 8th, 2009 08:45 PM
SoRare
April 24th, 2009 07:18 PM
Quick Reply: Disassemble trunk mechanism on 41
