1934 Oldsmobile 213 Flathead
Hello All, I am posting in regards to my 1934 GMC T16 project. This truck has, to best my knowledge, an Olds 213 in it. I am trying to identify the numbers on my block. I have found them amd emery clothed them. I have a total of 7 digits showing comprised of 2 questionable marks followed by 5 numbers. I have only found one other post online including a 213 block number and theirs was stated as being a 1937 with a number beginning as like follows "T12345". Can anyone shed some light on any 213 info?
I don't believe the Olds engine was used in the GMC T16 until 1936 when GM Export started producing Oldsmobile Trucks for Export.
This link will give you some details but if you can post some photos of the engine on both sides and particularly the head then I'm sure we can confirm if it is an Olds engine.
https://www.gmheritagecenter.com/doc...TORY_MAR09.pdf
old36
May 1st, 2017 07:39 PM
titanic122
February 20th, 2016 07:42 AM
evans_78
March 7th, 2013 05:04 AM
