55 Olds Hydramatic leak, what kind of fluid to use?
I just got my 55 Super 88 off the shipping trailer and drove it into the garage. There is a significant red puddle under the transmission where the driveshaft enters it. Here are some pics. The dipstick is dry when it is idling.
Any idea how to fix and what ATF fluid I should use? I hear Dexron III is the best. Any advice is appreciative...dont want to wreck the car 20 minutes into owning it.
Thanks,
TOM
Thanks,
TOM
X2 what Olds64 said. All the numbered Dexron can be intermixed and are compatible with each other.
It looks like you leak is the rear transmission seal, one of the easier one to get to and fix.... Tedd
You've got some good advice so far. Here's another thing you might want to consider. That slip yoke calls for lube every 5,000 miles. Instead of changing out that plug for a fitting every 5,000 some owners just install the fitting and leave it, making the job a bit easier. It's best not to use a pneumatic tool to do the lubing. Just give it a "hand job" lubricator.
You may want to check the slip yoke for leaking out the yoke itself. Some of the yokes use a expansion plug to keep the oil from leaking out. If the leak is at the back of the extension housing, then the oil seal is the culprit.
Fitting
I just had mine rebuilt a few months ago and with the exception of the tail shaft seal leaking it was a great job. I imagine it was just a bad seal. I will just get a new one and replace it myself. I use the high mileage Dexron that is O'Reilys brand. I don't know that it is any different.
70worm
Nov 22, 2012 09:19 AM
cfair
Brakes/Hydraulic Systems
Jun 8, 2009 12:37 AM
