'56 Power Brake Push Rod is locking up
Old Jun 6, 2020 | 04:44 AM
ignachuck's Avatar
Frank Ignachuck
Recently, the Bendix power brake push rod on the '56 has been locking or binding up once in a while. Tap the brake pedal,the pedal locks. Release and tap again and it works fine for the next eight or nine times. If I drive with slight pressure on the brake pedal (which isn't the right solution) it never locks.
I replaced the brake pedal pad because the cup that receives the push rod on the underside was broken off and the push rod was wobbling. That needed to be done, but didn't solve the problem.
Anyone had this problem? Suggestions?
Thanks in advance.
rcdynamic88
Brakes/Hydraulic Systems
Aug 6, 2014 07:41 PM
mikeman
May 20, 2014 02:27 PM
Rocket North
May 7, 2014 07:11 AM
Fitti Six
Mar 26, 2013 07:59 PM
costpenn
Dec 29, 2012 02:53 PM
