power brake booster fail?
Old May 13, 2014 | 02:29 PM
mikeman's Avatar
In the past few years I have replaced the power brake booster 3 times.They work fine after installation but it seems that if i have to brake hard it fails and there are no more power brakes. It's a 71 cutlass supreme convt. 350 2 bbl
Last edited by mikeman; May 13, 2014 at 02:32 PM. Reason: forgot to say what type of car
Old May 13, 2014 | 03:12 PM
Describe fails... leaks, pedal feel, etc?
Old May 13, 2014 | 05:26 PM
I agree we need a better description of the failure.
With 3x failures that you have experienced after hard braking, the only thing that comes to mind is the push rod may not be adjusted properly and it's too long, so when you stand on the pedal you are breaking something inside the booster.
Maybe that isn't even mechanically possible, but it's all I can come up with from your description.
Old May 13, 2014 | 07:20 PM
Wow. Most of these last fifty years or more without any service or maintenance of any kind.
What are you doing to kill three in a few years?
Old May 14, 2014 | 05:57 AM
mikeman's Avatar
failure
What happens is the brake pedal becomes hard to press and you have to really stand on it and its like the power is gone from the "power" brakes. Thanks guys
Old May 14, 2014 | 06:06 AM
Yes, that describes a failed booster, but what could you be doing to cause it?
Old May 14, 2014 | 06:53 AM
Oldsmaniac's Avatar
Perhaps you have a flimsy vacuum hose on it from the intake and it is collapsing causing a loss of vacuum to the booster?? Just a guess.
Old May 14, 2014 | 07:01 AM
When you replaced the booster, are you sure you used the right hole on the brake pedal when reconnecting the new clevis? 2 failures so close together also makes me wonder about the vendor of the booster.
Old May 14, 2014 | 07:16 AM
This needs to be verified, but I don't think it's physically possible to force the clevis to align with the wrong hole. It just doesn't move enough, at least not on an A-body.
Old May 14, 2014 | 07:34 AM
Actually it can. I noticed that when I replaced my booster 3 years ago. The 71 and 72 will have the same assembly.
Old May 14, 2014 | 08:01 AM
pogo69's Avatar
morgan
i agree with MD... these things last forever and to go thru three??? you must have something else going on like a frozen drum,caliper,vac leak...
Old May 14, 2014 | 08:09 AM
droptopron's Avatar
delete
Are you having your's rebuilt or getting a repro?
If its a repro I'd question the quality.
Old May 14, 2014 | 09:53 AM
Octania's Avatar
too much cam, retarded timing => low vacuum?
What's a vacuum gage say?
Old May 20, 2014 | 02:27 PM
mikeman's Avatar
just got a vacuum gauge i will check it soon. thanks
delta_88_germany
Oct 12, 2013 11:35 AM
Octania
Aug 20, 2013 08:01 PM
don71
Site Help
May 27, 2012 08:14 AM
Aceshigh
Sep 27, 2011 09:43 AM
dhartley72
Apr 9, 2010 12:20 PM
