Any suggestionson next course of action
Speedo quit working. The cable has some dirt and grit in it but I can turn the cable manually and get it to register on the speedometer. So I replaced the gear and still doesn't work. From what I can see from the outside the gear in the transmission looks good and feels like the teeth aren't stripped.
Before I take car in and spend the money to have the gear replaced in the transmission is there something else I should be checking first that would be causing this? Speedo was working when I fist got the car.
coldwar
March 15th, 2010 06:22 PM
Aussie67Delta88Custom
February 14th, 2008 04:49 AM
