Any suggestionson next course of action
Old Jun 15, 2014 | 06:09 AM
davoaz's Avatar
Speedo quit working. The cable has some dirt and grit in it but I can turn the cable manually and get it to register on the speedometer. So I replaced the gear and still doesn't work. From what I can see from the outside the gear in the transmission looks good and feels like the teeth aren't stripped.
Before I take car in and spend the money to have the gear replaced in the transmission is there something else I should be checking first that would be causing this? Speedo was working when I fist got the car.
Old Jun 15, 2014 | 06:25 AM
Grace Stinespring-Welch's Avatar
sounds like the gear drive in the tranny may have went out.
Old Jun 15, 2014 | 10:46 AM
As noted, sounds like the speedo drive gear. Before paying to have this gear replaced, however, be sure to replace the speedo cable and sheath. Any "grit" or friction will just destroy the new gear also.
Old Jun 16, 2014 | 05:58 AM
davoaz's Avatar
Do you know length of cable needed? There seems to be numerous lengths of cable. I'm away from Car right now and can't pull out the old cable to measure.
csouth
Sep 7, 2012 08:52 PM
The Stickman
Feb 25, 2011 02:44 AM
coldwar
Mar 15, 2010 06:22 PM
Aussie67Delta88Custom
Feb 14, 2008 04:49 AM
Swed Olds
Sep 13, 2007 08:55 AM
