1966 delta 88 control arm
Old Jun 24, 2024 | 11:26 AM
Delta88rocket123's Avatar
My left front lower control arm broke off today and im having trouble finding a replacement part. Any advice to where i can find a new one that fits ?
Old Jun 24, 2024 | 12:51 PM
Create a thread in the Parts Wanted section of the Classified forum here >>> https://classicoldsmobile.com/forums/parts-wanted-13/
Old Jun 24, 2024 | 05:36 PM
Charlie Jones's Avatar
Phantom Phixer
To help expand your search.
The parts book lists the lower control arms as the same from 1965 thru 1970 All except F-85 and Toronado.
The factory part numbers are 402080 (RH) and 402081 (LH)
Thru 1975 - Oldsmobile Chassis and Body Parts Catalog - ClassicOldsmobile.com
Old Jun 24, 2024 | 07:45 PM
You won't find a new one. Good used from another 1965-70 Olds full size is your only option. No, Caprice/Impala parts do not fit. Be aware that the upper ball joints for the 1965-70 full size cars are also very difficult to find new. They are RH/LH.
Old Jun 25, 2024 | 04:46 AM
Here are some specialty salvage yards you can check.
https://www.dvap.com/
http://www.ctcautoranch.com/
You also might check here for ball joints and control arm bushings.
https://www.kanter.com/
https://www.fusickautomotiveproducts.com/
Old Jun 25, 2024 | 05:17 AM
Are the control arms from delta/starfire/88/98 interchangable ? i found one used for each model but would like to get the least rusty if they're all the same
Old Jun 25, 2024 | 05:27 AM
Both Charlie & Joe have already addressed your question.
Old Jun 25, 2024 | 06:01 AM
Old Jun 25, 2024 | 08:20 AM
Phantom Phixer
Yes.
Old Jun 25, 2024 | 09:46 AM
Once you get a control arm let us know if you find some ball joints. Hopefully Kanter at least carries cheapies.
Old Jul 28, 2024 | 01:34 PM
cfair's Avatar
Sorry to hear this news.
You’ll find a control arm at some point, but a good safety step is to have it checked for cracks under a UV light after magnaflux dip/treatment. Others here know more about safety checking than me. Point is since you’re dealing with used parts, do your best to confirm they are sound & safe. It’s also a good thing to note the nominal mileage of the donor car.
I recently learned that ball joints for these arms were made in standard and oversized diameters. I’ve had 2 lower A-arms break in 40 years with 2 similar cars and I wonder if the oversized ball joints contributed to the failure.
If it were me cleaning up this mess, I’d replace all lower bushings and ball joints presuming I could find the parts. Good time to evaluate all your steering gear while you’re in the front end if it’s loose/worn.
One more classic junkyard to check would be Turner’s Auto Salvage in Fresno, CA. You might also check in with GM Sport/Salvage in Stockton CA. GM S/S focuses on Camaros and A bodies, but they used to have a smattering of big car parts too.
Good luck.
Chris
Old Jul 28, 2024 | 03:48 PM
Last post from OP indicated that he'd found control arms, which I took to be good news.
You do provide some useful tips for safety checking and fitting ball joints, though.
Upstate 442
Suspension & Handling
Mar 30, 2023 01:07 PM
Vistabrat72
Feb 22, 2018 05:35 PM
Username
Oct 17, 2017 02:22 AM
Gauchobyte
Jul 20, 2017 06:33 PM
jbrookman198422
Mar 8, 2014 10:35 AM
