What valve seals to use with dual valve springs?
Old April 4th, 2022, 02:58 PM
HarrySlother's Avatar
I'm just realizing that I'm probably going to need to change the valve seals after breaking in the cam with just the outer spring. I'm not sure yet because I haven't tried putting the inner springs in yet but looking at the extra fel pro seals I have they're not going to work, but I used some other brand umbrella seals.
My options are pull heads and get them machined for different seals? What seals would I do that with?
Run no valve seals but I don't think that will be good for a daily driver.
Is there any seals that I can use with out machining? Anyone have experience with this?
HarrySlother is offline
Old April 4th, 2022, 04:54 PM
442Harv's Avatar
If you don't want to spend to much money, just put the umbrella type back on, they work.
442Harv is offline
Old April 4th, 2022, 05:51 PM
I don't think they will work with the dual spring but I'll try
Old April 5th, 2022, 11:37 AM
BillK's Avatar
Depending on what your inner spring measures a Chevy umbrella might work but it may also be too small to go over the guide. You really wont know till you pull the springs off and take a look.
BillK is offline
Old April 13th, 2022, 08:15 AM
brownbomber77's Avatar
Cut the valve guide down to fit a modern positive seal or measure what you have and purchase a modern positive seal to fit.
brownbomber77 is offline
rjh45
February 6th, 2021 08:29 AM
Achcoastal
July 23rd, 2019 05:44 PM
54oldsmobile88RW
February 16th, 2018 08:23 PM
MaxDog
February 27th, 2012 08:12 PM
Lady72nRob71
July 14th, 2011 07:24 PM
Quick Reply: What valve seals to use with dual valve springs?
