valve stem keepers
Old Jul 22, 2019 | 04:27 AM
Achcoastal's Avatar
valve stem keepers
going to replace valve seals on my 1970 455 with E heads.would like to order new keepers in case the current ones are worn etc. new ones come in 7 degree or 10 degree.both say they fit my engine.i could order both but i would like to know which ones should be in there. heads are stock as far as i can tell
Old Jul 22, 2019 | 05:12 AM
67OAI's Avatar
Old(s)GuysRule
Stock are seven degree.
Old Jul 22, 2019 | 06:23 AM
Achcoastal's Avatar
ok, thanks for the reply 67oai
Old Jul 23, 2019 | 12:45 AM
brownbomber77's Avatar
On replacing valve stem seals, you can use Ford 302/351 from the 80s on up for the positive seal instead of umbrella type. They do fit over the valve guide with no modification.
Old Jul 23, 2019 | 10:09 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
And do not replace the keeps if you're just doing stem seals. If the keeps are worn so is the valve stem. Now you gambling with sucking a valve.
Yes, inspect everything for excessive witness marks and then decide to replace things a "system" if anything fails inspection.
Keep(ha) the same keeps with the same spring retainer with the same valve stem.
So, in other words, strict attention to detail making sure each part goes back with the part it was born(broken in) with. Same goes for the pushrods.
Old Jul 23, 2019 | 10:24 AM
Achcoastal's Avatar
Ok good advice, I’m just going to use umbrella seals for now and hopefully that’s fixes my fouling plug problem
Old Jul 23, 2019 | 05:11 PM
BillK's Avatar
Not sure about the others but every valve keeper that comes off a head in my shop goes in the scrap metal bin. I dont care if it is a 10 cent stock one or a $60 set of Crane Posistops. They simply do not get reused. Been doing it that way for over 32 years and have never had a problem. Cheap insurance.
That is my opinion only,
Old Jul 23, 2019 | 05:44 PM
cutlassefi's Avatar
X2. New, good machined ones are inexpensive. No reason not to change them.
Inline
Nov 25, 2018 08:58 PM
louie
Feb 21, 2018 08:53 AM
54oldsmobile88RW
Feb 16, 2018 08:23 PM
rockettruck
Nov 5, 2012 07:28 PM
MaxDog
Feb 27, 2012 08:12 PM
