Water neck to water pump hose 1972 olds 350
Old October 20th, 2017, 02:10 PM
Chris
Oldssupreme's Avatar
Hi guys! Silly question but I'm heading to the auto parts store to get the Water neck to water pump hose for my 1972 olds 350 and I forgot the old piece of hose. I believe it's double walled but I don't remember the size. Anyone know off hand? It's that short 3 or 4 inch piece. Thanks! It's a 40 minute drive back home so I appreciate your help!
chris
Oldssupreme is offline
Old October 20th, 2017, 02:17 PM
Proud Viet Nam Veteran
redoldsman's Avatar
I believe that is a preformed hose made for the Olds 350 and 455.
redoldsman is offline
Old October 20th, 2017, 02:28 PM
Paladin31's Avatar
Here you are buddt
OLDSMOBILE 1972 CUTLASS 5.7L 350cid V8 Cooling System Bypass Hose
Price
ACDELCO 30125 {#509017, 88909066} Professional; Straight; 3/4" (50 psi)
.84 per foot at rock auto
regards, Brett
Paladin31 is offline
Paladin31's Avatar
damn spellcheck, Buddy
Old October 20th, 2017, 02:36 PM
Chris
Ok. So 3/4" 50 psi Thanks so much
Brett! So instead of waiting for Rock auto to ship can I get that at a generic auto parts store?
Old October 20th, 2017, 02:40 PM
Paladin31's Avatar
it would be regular radiator hose, buy a couple feet of 3/4" ID hose and cut as needed/ Your car should have the formed steel tube on the water neck that makes it a straight shop to the water pump nipple
Brett
Old October 20th, 2017, 02:42 PM
Chris
Ok Brett. So just to make sure I got it right , heater hose is different than radiator hose right? Because i have 3/4" heater hose but it doesn't seem as thick as the radiator hose.
Old October 20th, 2017, 04:48 PM
Paladin31's Avatar
you can buy bulk hose at any auto parts store. yes it is heater hose, just make sure it's stamped for 250deg F (or more) & 50psi burst (or more)
Brett
Old October 20th, 2017, 04:54 PM
Chris
Thank you so much Brett! Truly appreciated!
Old October 20th, 2017, 04:55 PM
Paladin31's Avatar
Not a problem Chris, its all a part of the Brotherhood!
Brett
Gravy Waves
September 7th, 2014 09:53 AM
dnmfranco
August 3rd, 2013 05:05 PM
OldsCutlass70
May 21st, 2013 06:31 PM
eddieunderground
February 11th, 2012 07:09 AM
shaks 442 clone
July 18th, 2007 05:03 AM
Quick Reply: Water neck to water pump hose 1972 olds 350
