Olds Gold Engine paint. (72 350 Rocket)
Old Nov 18, 2012 | 10:39 PM
AirborneRME's Avatar
I've got a 72 Cutlass S that I recently bought for my dad. I'm looking for some reproduction engine enamel in that Olds Gold. anyone have any leads or suggestions on what brand is best to go with?
Any pics/examples would be great. Thanks!
- R.J.
Old Nov 19, 2012 | 03:11 AM
If you use your Search function, you will find threads on this subject here, here, here, here, here, here, and here, for starters.
Old Nov 19, 2012 | 03:37 AM
Del70's Avatar
Maybe someday..the original paint Mfg. and color codes (mix) for the 68-72 Olds Eng gold and 455 blue will be discovered in some factory paperwork..
Old Nov 19, 2012 | 04:05 AM
The problem with that is that all of the raw ingredients (pigments, binders, base, etc.) have changed since then, and the originals are no longer available.
An experienced paint man can often figue out general equivalences, but exact translations are difficult to impossible.
Also, with constantly tightening environmental regulations, in a wide variety of jurisdictions, the raw ingredients of today may not be those of tomorrow.
Old Nov 19, 2012 | 05:18 AM
Roger Kent's Avatar
Olds Gold Engine Paint
Hi, an American company called POR supply a one pint tin of Olds Gold engine paint and is good for temps up to 300f. If you go to http://www.por15.com/Engine-Enamel/products/7/ you will see they do either the paint or a complete kit option.
I've used it myself and can say it has lasted well on my 1975 Delta 88 Royale under English weather conditions. If you want to see the Olds she is on www.kentuckycars.co.uk
Roger Kent
Old Nov 19, 2012 | 06:39 PM
Thanks, may try going to napa and seeing if they can mix some!
-R.J.
code26
Feb 9, 2015 11:09 AM
OldsW29
May 21, 2014 03:25 PM
Grant1424
Apr 19, 2012 07:33 PM
cutlassKing
Nov 29, 2010 03:05 PM
RAMBOW
Mar 14, 2010 07:44 AM
