Cutlass 71 engine rebuild
Old Feb 4, 2013 | 08:46 AM
balage's Avatar
Hello Guys,
Finally my 71 Cutlass Supreme's engine is being rebulit. Among others I am thinking of a new camshaft to gain some more HP. (I have Edelbrock carb) Could you advise me some shops, where should I it by from? (Most parts probably will be ordered from rockauto).
Thanks a lot
Balage
Old Feb 4, 2013 | 01:53 PM
DoubleV's Avatar
If you tell us exactly what cam you want to get, I'm sure someone would be able to provide you with some good choices.
Old Feb 4, 2013 | 02:19 PM
cutlassefi's Avatar
Need to know what other pieces you'll be using, pistons, intake, headers?, rear gear, tranny, desired performance etc.
Old Feb 5, 2013 | 05:51 AM
balage's Avatar
Hm, allright. Everything is stock (350 with 3speed aut.trans).
How about some good shop names to look around first?
Old Feb 5, 2013 | 01:13 PM
DoubleV's Avatar
OK, how about Rocket Racing, BTR Performance, or cutlassefi who just posted here. A quick search on the internet would bring up plenty of others too.
Old Feb 6, 2013 | 12:58 AM
balage's Avatar
Thx!
I've found shops, but i don't know which one is good, which one is not recommended...
Old Feb 6, 2013 | 01:41 AM
DoubleV's Avatar
Avoid Monello Performance Products at all costs. There are a couple of others that I personally don't like or would do buisiness with, but I'd rather not name names. I've never heard a bad thing about BTR, so you might want to start there.
Old Feb 9, 2013 | 10:46 AM
drop top olds's Avatar
Use someone familiar with Oldsmobile engines. Cutlassefi, BTR, Rocket Racing and others will be glad to assist. I would also recommend you purchase your cam, lifters, etc from the person that provides the advice!
Old May 12, 2013 | 08:34 AM
balage's Avatar
Engine and th350 rebuilt. Runs smooth, but i have no kickdown. The carburetor (edelbrock 6xx) has no bracket for it, so i could not connect the kickdown cable. The car accelerates in 3th gear no matter how fast and deep i press the pedal. Interesting, but previously (before the restoration) the th350 was changing back when i suddenly pressed the pedal without this cable connected to the carb! (dont know if it matters or not, but some vacuum pipes were in wrong place...)
I'll post pictures later, to demonstrate what i am talking about.
Old May 12, 2013 | 09:48 AM
balage's Avatar
I marked the two i need to connect somehow...
http://www.imagebam.com/image/c98a73254225872
Old May 13, 2013 | 06:16 AM
Oldsmobiles with a TH350 had the kickdown cable attached to the accelerator pedal, not the carb linkage (that's a chevy thing).
Old May 13, 2013 | 08:39 AM
balage's Avatar
Thank you, you must be right! I will check the accelerator pedal!
Old May 13, 2013 | 09:19 AM
72cutsupreme's Avatar
I will have to look into this too. My car has never kicked down he entire time i have owned it lol
Old May 13, 2013 | 10:46 AM
balage's Avatar
Could you post a picture how it is done?
Old May 13, 2013 | 10:52 AM
I will have to scan the information from my Chassis Service Manual. Will try and do that tonight.
Old May 13, 2013 | 10:56 AM
balage's Avatar
Thanks!
(Or just take a photo of the cable on the accelerator pedal... )
Old May 13, 2013 | 03:54 PM
tinner's Avatar
Is Rocket racing still in business?
Old May 13, 2013 | 06:00 PM
DoubleV's Avatar
If they continue to rip people off the way they ripped me off, hopefully they won't stay in buisiness much longer. I know I mentioned them earlier in this thread, but that was before I found out Rocket Racing did a lousy job on my engine, charged me for work that wasn't even done, lied to me about the work that was done, and then ignore me when I tried contacting them about it. John Stolpa is a liar, a crook, and a coward. Take your buisiness elsewhere!
Old May 13, 2013 | 06:02 PM
A quick internet search found this picture from a post here on CO:
https://classicoldsmobile.com/forums...cutlass-s.html
Old May 13, 2013 | 06:05 PM
coppercutlass's Avatar
Chevy budget Olds powered
Rocket racing has been good to me. remember john has guys working for him. I work in the collision repair field and on of my bosses once told me. there is no such thing as a bad bodyshop just bad body man and painters. take it with a grain of salt john has been good to me and i have never had issue with him or his work.
Old May 14, 2013 | 01:52 AM
DoubleV's Avatar
I'm glad for you but he outright lied to me about many many things and did crap work on my engine. When he was caught, he refused to contact me because he doesn't want to accept responsibility for anything. The point is, if you know RR/John Stolpa is capable of doing crap like that to a customer, do you really want to give them your money? I certianly don't and will continue to warn others about their unethical/illegal buisiness practices, because I don't want to see anybody else have to go through all the BS I had to. Next time you talk to that lying sack of crap, feel free to tell him that.
Old May 14, 2013 | 04:15 AM
Hey Balage,
Looks like Fun71 posted some good information for you. I was having trouble with my scanner at home... Good luck on your task.
Old May 14, 2013 | 05:46 AM
balage's Avatar
Thanks for everyone!
I did a quick search last night in the car, and found funny things. The accelerator pedal has the cable connected! But on the other side of the firewall the cable is cut! It was hidden behind something. I also have a cable coming from the TH350 going to the carb as it is shown on my pic.
So i think i can do 2 things:
- buy a complete kickdown cable and connect
- do a console on the carb for the existing one.
Old May 14, 2013 | 06:04 AM
brown7373's Avatar
Here is the linkage adjustment from the 72 Service Manual, which I think is the same. So where did my attachment go? I'll try again.
Old May 14, 2013 | 06:10 AM
brown7373's Avatar
Linkage adjustment from 72 Service Manual. File was too large onm the first attempt.
File Type: pdf
Old May 14, 2013 | 06:14 AM
balage's Avatar
Thanks! All i need is a cable now . Ebay?
Old May 14, 2013 | 09:24 AM
Octania's Avatar
Correction:
SOME Oldsmobiles with a TH350 had the kickdown cable attached to the accelerator pedal, not the carb linkage, as seen in the pedal photo nearby.
I think it was 68? 69-72 that used this system.
The CABLE is hard to find mainly because it is ignored by the Parts Manual writers. You have to have a GOOD counter man to find it. When I finally found one I recorded all the info I could in the PN database:
Advance Auto PN
4210
"CABLE, downshift or detent, 69-72 F85 TH350.
Cable runs to FIREWALL and GAS PEDAL
Also on box:
015-3841-6,
91-32-107254414,
SKU=3925188,
Barcode 51784
Crossovers: CA-1950, Y-104 [Made in Israel]
Google on that SKU leads to lots of places including
http://www.google.com/url?sa=t&rct=j...46471029,d.aWc
https://classicoldsmobile.com/forums...ent-cable.html
Wherein a clever feller called Octania sets forth similar information.
Old May 14, 2013 | 10:06 AM
brown7373's Avatar
I bought a downshift cable and throttle cable from Fusick
Old May 14, 2013 | 10:16 AM
70cutty's Avatar
Beer Connoisseur
I bought the kickdown cable from parts place on Ebay. $69.99 + $8 for shipping.
http://www.ebay.com/itm/1968-72-CUTL...074216&vxp=mtr
Old May 15, 2013 | 09:30 PM
balage's Avatar
It seems to be quite expensive, so i think i go for the carb console...
jensenracing77
Jan 12, 2016 02:02 PM
ratterberry
Jan 11, 2012 09:50 AM
442dreamer
Aug 23, 2011 07:28 AM
Gary's 2 442-S
Aug 14, 2011 12:04 PM
442oldslawyer
Apr 29, 2010 09:22 PM
