67 330 needs new distributor
Old Jan 13, 2021 | 04:08 PM
brianbeez67's Avatar
Looking to rebuild or replace my original distributor with the same style setup. Any suggestions? Kits out there that have the correct springs and dist. gear ?
Old Jan 13, 2021 | 09:11 PM
You can get a rebuilt from your local auto parts store and transfer the weights from your old distributor if they are different before returning the core.
Old Jan 14, 2021 | 04:25 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Everyday Performance sells a rebuild kit
http://www.everyday-performance.com/...egory=21548473
Ken also can rebuild your distributor and do a custom curve as well.
Old Jan 17, 2021 | 09:09 AM
Went to that web sight, but did not see a gear with the rebuild kit. Thought it was important to change the gear when changing to a new camshaft?
Old Jan 17, 2021 | 09:15 AM
Not unless you have a billet roller cam.
Old Jan 17, 2021 | 12:44 PM
Sugar Bear's Avatar
Consider sending your distributor to a private rebuilder that will re-bush it, put it on an old school Sun distributor machine and set the advance curve accurately. You'll have the original distributor tuned better than when it left the factory.
Good luck!!!
Old Jan 25, 2021 | 04:45 PM
Found a rebuilt unit at NAPA for about 150$ as. A backup
F85 330 ctls
Jan 5, 2020 07:27 AM
stevengerard
Dec 20, 2018 01:53 PM
dpt618
Sep 22, 2013 04:32 PM
Joah_from_Alberta
Jun 9, 2013 03:12 PM
rroth01
Apr 23, 2008 07:03 PM
