1980 442 engine build
Old Apr 14, 2019 | 01:22 PM
  #81
olds 307 and 403's Avatar
Out of Line, Everytime😉
That will work with your current open? carrier or a 2 series posi carrier. There are thin and thick gears available in most popular ratios, that is why they say 2 or 3 series. This is because most factory carriers are 2 series. For your rpm calculations add 250 to 300 rpm for converter slippage. So with a stock 25" tall tire, you will run 2900 at 60 mph. Seeing how everything is far away where we live, a 3.08 gear might be better.
Old Apr 14, 2019 | 09:34 PM
  #82
Kyle's77cutlass's Avatar
I dont know, I sent them a message.
Now all things considered, doing the engine, changing the gear ratio, 2200 stall, may as well yank the trans and rebuild it as well.
Something else to look forward to. lol
Old Apr 15, 2019 | 07:06 PM
  #83
Standing here looking at the block, what's your thoughts on an electric fuel pump?
Old Apr 15, 2019 | 07:42 PM
  #84
You need a block off plate and a quality, quiet fuel pump properly plumbed. It makes Procomp or Edelbrock aluminum heads an easy swap, mechanical pumps won't work with them on a 350.
Old Apr 15, 2019 | 07:58 PM
  #85
I am sticking with the iron. Hope to get the 7a's and 8's in the shop tomorrow for magnafluxing.
Old Apr 15, 2019 | 09:20 PM
  #86
Just pick up the Carter Muscle car series mechanical fuel pump. Without return line
https://www.summitracing.com/parts/crt-m6108/
With return line.
https://www.summitracing.com/parts/c...ake/oldsmobile
Old Apr 15, 2019 | 09:25 PM
  #87
Yeah was looking at the pumps, just making it more complicated going with electric. Will stick to old school
Old Apr 16, 2019 | 08:56 PM
  #88
Well heads of to the shop today for magnafluxing, hope to start porting them soon.
Block all wrapped up and ready to ship off to the shop for machining.
Old Apr 18, 2019 | 11:42 AM
  #89
Well both sets of heads checked out good.
Have a set of 7a's and 8's to work with.
Hope to start porting and polishing them this weekend. Noticed a big difference in the pocket from the 7a's and 8's. The 8's are shaped differently around the guide and is no slope on the wall that comes into the chamber. It's a straight wall,I take it this is why the 8's dont flow as well.
Old Apr 18, 2019 | 01:50 PM
  #90
coppercutlass's Avatar
Chevy budget Olds powered
If you want a better mechanical fuel pump try the RobMC fuel pump . it may interfere with you A/C if you plan on running it if you are not gonna run A/C it's worth the money.
Old Apr 18, 2019 | 01:53 PM
  #91
Going to keep the A/C in the car.
Old Apr 19, 2019 | 05:12 PM
  #92
oldsmobiledave's Avatar
Converter
Originally Posted by Kyle's77cutlass
Thinking about an 1800 or so
FYI the original converter used in the T350 for a 1980 442 was a 2400. Do not use less.
Old Apr 19, 2019 | 05:22 PM
  #93
76olds's Avatar
Hookers under Hood
Nice work at cleaning up the block etc. Hope everything checks out OK Kyle.
Old Apr 19, 2019 | 05:43 PM
  #94
That is good info, should be about right as is, as long as it is original.
Old Apr 19, 2019 | 05:59 PM
  #95
So if the factory stall is already 2400, wont make much sense to buy a 2500?
Old Apr 19, 2019 | 06:19 PM
  #96
7a's and 8's heads. Start porting them soon
Old Apr 19, 2019 | 06:44 PM
  #97
I heard rumor there was a better converter in those cars but didn't want to say. It might not hit the 2400 stall rating but it is no doubt a huge improvement over the regular 1600 flash stall everything else got. I know the 2400 stall behind the 80's Hurst/Olds and 442 stalled around 2000 rpm. But that was behind 170-180 hp and 250 ft/lbs of torque.
Old Apr 19, 2019 | 06:56 PM
  #98
Okay. I am guessing my build will be up towards
300 hp.Around the 9.5 to 1 ratio. Ported heads, roller cam a rockers
Old Apr 19, 2019 | 09:32 PM
  #99
Which why it should stall higher than the stock 350 and you should be good to run as is.
Old Apr 21, 2019 | 05:15 PM
  #100
Started some dental work
Old Apr 21, 2019 | 08:10 PM
  #101
Done for the day, another crack at porting tomorrow
Old Apr 22, 2019 | 04:31 AM
  #102
cutlassefi's Avatar
Don’t be too hell bent on removing a bunch of material out of the ports. You’re not going to be spinning it that high so you don’t need to increase the volume by much, just the flow.
Old Apr 22, 2019 | 09:26 AM
  #103
Yep, Not going hard at it.
Just cleaning it up so they flow nicely, will try to teardrop the bosses tho. Not sure how nice they will be, not much material to remove
Old Apr 22, 2019 | 01:26 PM
  #104
Playing with the exhaust boss, tear dropping.
Dropping it so the the point meets the center of the exhaust port
Old Apr 22, 2019 | 07:52 PM
  #105
Well started on the intake boss tonight. Let me tell you, porting is for a batchelor. Dam is my wrist sore
Old Apr 28, 2019 | 10:35 AM
  #106
looking a valley pan gaskets,
Fel-Pro FEL-MS96009
Sealed Power SLP-260-4010
Any insight?
Old Apr 28, 2019 | 10:56 AM
  #107
Well some parts are in, thanks to Mark. Hope more is in this week. 😁😁
Been steady week cleaning the heads up. 1 almost completed, other about half way. Be nice to ship those to the shop for rebuild soon.
Block was hot tanked last week, machining starts tomorrow.
Old Apr 28, 2019 | 12:48 PM
  #108
Those the 7A heads? The one pic almost looks like the #8 bowl area. Looking good, can hardly wait to see it all come together.
Old Apr 28, 2019 | 12:58 PM
  #109
Fel-Pro FEL-MS96009
Any insight?
The Felpro valley trays have always fit well. I have used other brands with luck, others have not. It is crazy Summit won't ship any of the tray gaskets. The the center crossover is why there is two different gaskets. The #8 heads have bigger crossover's vs the earlier heads.
Old Apr 28, 2019 | 05:14 PM
  #110
Yes they 8's. Wanted 7a's but scared to bring compression 10 or over. I am surprised, my first porting job and turning out nicely. Trying to find the proper tools here isn't easy. Lol Curious to see how they will flow. Even cleaning the oil ways so the oil has less resistance to get back to the pan.
Hope this head out Tuesday..
Old Apr 28, 2019 | 05:17 PM
  #111
Okay, well I will be filling the heat riser so shouldn't bother.
Old Apr 28, 2019 | 06:42 PM
  #112
Yes, basically the early gasket 96009 won't cover the #8's crossover passage properly but filling the heads should make it a mute point. Just get the more common Turkey tray for the 73 to 85 307, 350 and 403, MS96027.
Old Apr 29, 2019 | 08:41 PM
  #113
Okay thanks for the input.
Well heads cleaned up not to bad. I am impressed with my work with them, first time porting heads.
Took time tho, around 50 hours into them.
Now just weld center exhaust port and fill heat risers. The only issue with that, I have no scrap pistons. Threw a bunch out last year from the 394 I torn down 😟😟
Old Apr 30, 2019 | 10:14 AM
  #114
Scrap pistons are horrible buy an ingot . The aluminum in pistons is not very clean. You will end up with less than ideal material from my experience .
Old Apr 30, 2019 | 10:56 AM
  #115
Okay, what is an ingot?
Will try to goggle this
Old Apr 30, 2019 | 10:59 AM
  #116
Okay an ingot is a brick of metal, so a brick of aluminum?
Old Apr 30, 2019 | 05:54 PM
  #117
You can buy small hobby ingots online. Many home jewelry makers use the stuff.
Old Apr 30, 2019 | 06:20 PM
  #118
So needs to be aluminum?
Old May 1, 2019 | 08:02 PM
  #119
76olds's Avatar
Hookers under Hood
Looking good Kyle, Nice work !
Old May 1, 2019 | 09:21 PM
  #120
Thanks 76olds. I am debating to buy some valve grind material and polish them more. Was hard to do a nice job along the side if the chambers.
If I can find a small polishing disk for the diegrinder, will attempt once more before I ship to Winnipeg
