timing chain alingment question
Old Aug 4, 2014 | 04:56 PM
  #121
cutlassefi's Avatar
Originally Posted by Smitty275
Intake centerline is the point half way between the open and close points. So if one is right the others will be right. For most people it's easier to find ICL than to do the open/close events.
True but you also have to take into account that some cam manufacturers still grind their cams off Berco profiles. That will make them grow or shrink from the original spec depending on the master profile used.
Old Aug 4, 2014 | 04:59 PM
  #122
RandyS's Avatar
Originally Posted by captjim
Not trying to start an argument, but this is not correct. You have to find the highest point of lift on the lobe (Smitty explained this a couple of pages back), you can't go by the numbers at the lowest part of the lobe. Pardon me if this is not what you mean, but it sounds like you are saying to start at the bottom, check at .050, then rotate through and check again at .050, this will NOT give the the IC. Here is from Lunatis site,
Rotate the engine clockwise until maximum lift is reached. Zero the dial indicator and continue in
clockwise rotation until a .050 reading is reached. Mark the degree wheel at this time. Rotate the
engine counterclockwise until maximum lift is reached again. Continue counter clockwise rotation
until a reading of .070 is indicated. Now rotate the engine clockwise until the .050 is indicated on
the dial indicator. This operation will take up any slack that exist in the timing chain and gears.
Halfway between these two marks is the center on the intake lobe. An example of this might be
153" on one side of the approximate centerline and 63 deg. on the other side. By adding these two
figures you get a sum of 216 deg. This number halved gives 108 deg. This is your lobe center.
Tomato - Tomahto. Both ways will give you the exact same result for the ICL Good luck, I'm out.
Old Aug 4, 2014 | 05:03 PM
  #123
captjim's Avatar
I suppose, except that with the popularity of asymetrical lobes these days, it seems that there would be more margin for error.
Old Aug 4, 2014 | 05:32 PM
  #124
coppercutlass's Avatar
Chevy budget Olds powered
Ok so per the lunati spec card here goes
IN. opening @.050 is 10.5
IN. closing @.050 is 42.5
Ex opening @ .050 is 54.5
Ex closing @.050 is 6.5
duration is 233/241 @ .050
centerline is 106
I got on the number one
in. opening 10
in closing 40
ex. opening 54
ex. closing 6.5
#6 I got
In. opening10.5
in. closing 40
ex. opening 54.5
ex. closing 3.5 ( I had a weird spot for the indicator due to mu stand being a standard issue one)
All figures where @ .050
My lift @ 1.6 is 560 1.5 is 520
My centerline came out to 115
Duration is 230 on the intake and 240 on the ex.
what do you guys think.
I want to thank you guys a lot. Smitty nailed it on the head about the centerline that comment alone made me realize what I was doing wrong. All my figures where @ .050 now I know how its done lol. BIG THANKS GUYS
Old Aug 4, 2014 | 05:37 PM
  #125
captjim's Avatar
centerline is 106
in. opening 10
in closing 40
ex. opening 54
ex. closing 6.5
#6 I got
In. opening10.5
in. closing 40
ex. opening 54.5
How did you arrive at 115 IC ? It looks like the valves are pretty much opening and closing correctly.
Old Aug 4, 2014 | 05:47 PM
  #126
40 @ the intake opening is 220 plus 10 is 230 devide by 2 and that 115 . I went with the higher number because 40 plus 10 is 50 and that would not be right. that is with me checking the opening right @ .050 and then .050 before it closes.
Old Aug 4, 2014 | 05:52 PM
  #127
captjim's Avatar
None of that makes any sense to me, but I can assure you that 115 is not correct.
Old Aug 4, 2014 | 06:02 PM
  #128
cutlassefi's Avatar
Apparently I posted for nothing, you didn't follow my formula.
230 duration divided by 2 = 115. Opening is occurring at 10btdc. 115-10 is? 105, that's your intake centerline. You all made this way too difficult.
And .560 lift with a 1.6 rocker is .350 lobe lift, the intake lobe is off that much? Really? How much do the lifters rise from dead zero to max lift? Lift on intake and exhaust is different correct?
Old Aug 4, 2014 | 06:04 PM
  #129
So my question is, after this exercise how far off is the cam from where it would be set by lining up the dots?
Old Aug 4, 2014 | 06:10 PM
  #130
cutlassefi's Avatar
On which keyway? Kind of hard to tell visually what's just a few degrees one way or another.
Old Aug 4, 2014 | 06:11 PM
  #131
Same place eric dot to dot but I Learned a lot and Mark efi im sorry I forgot about your formula. thank you for correcting that . I apologize for that. Yes I now know how and I will know now.
yes the lift is different on intake and exhaust.
mark my question is if you multiply 350 by 1.5 it comes out to 525 . So I think what you said about the sbc journal may be right.
It may have been made difficult but I learned there is a few different techniques and I now know my mistake too much info lol.
Old Aug 4, 2014 | 06:34 PM
  #132
rubeng442's Avatar
That's sort of what I mean. If the .050 numbers are good, screw the ICL. It's meaningless at that point.
Old Aug 4, 2014 | 07:06 PM
  #133
Sampson's Avatar
Thanks guys I have learned a lot by following this thread. Line the dots up and you are good!
Old Aug 4, 2014 | 07:11 PM
  #134
not really that simple sampson . I understand what these guys are talking about as far as checking things out. This isn't a stock rebuild. Im going to be beating the tar out of it. It is important I know these things.
Old Aug 5, 2014 | 12:26 AM
  #135
rustyroger's Avatar
'87 Delta 88 Royale
I'm glad you finally got it right, let us know how far out (if any) the timing dots are please.
And here is an example of an exasperated OP getting conflicting advice, and if you'll forgive me, not understanding some of it properly at first.
But nobody lost the plot and started venting at other posters, maybe a few posts were a bit testy, but despite the frustrations and misunderstandings of coppercutlass and everyone who offerd help and advice this thread has hopefully had a happy ending.
Brownie points all round I say .
Roger.
Old Aug 5, 2014 | 01:10 AM
  #136
Smitty275's Avatar
Engine Builder
All's well that ends well. He persevered until he got it right. Plus a few others may very well learn from his mistakes and misunderstanding.
Nilsson
Jan 23, 2015 10:02 PM
s i 442
Jun 20, 2014 10:08 PM
hueveaj
Oct 9, 2013 05:55 AM
naphtali5725
Mar 6, 2013 09:42 AM
1arunem
Feb 15, 2009 04:48 PM
