Gear question
Old May 27, 2021 | 06:02 AM
Jhucks03's Avatar
Gear question
Anybody want to take a stab at whether a 4.10 is too much for the strip? Mostly 1/8. Occasionally a 1/4. Current combo is 3.42 with a 28” tire (455/TH350) leaving at ~2200-2500 foot brake
Old May 27, 2021 | 06:22 AM
7314haywood's Avatar
Go to Wallace Calculator. It will have formula to see max rpm with normal converter slippage. My guess your safe.
Old May 27, 2021 | 06:29 AM
Jhucks03's Avatar
Calculator says ok, but was looking for real world. Those calculators sure are handy and pretty amazing what you can get out of them.
Old May 27, 2021 | 08:15 AM
For what it's worth 4.30 gear 30 tall tire and 7% converter slip I went 6800 rpm. Pretty accurate info as I have a data logger on race car.
Old May 27, 2021 | 12:01 PM
Duh's Avatar
Duh
For final drive gear ratio you really need to look at your MPH and RPM.
Old May 27, 2021 | 12:16 PM
Jhucks03's Avatar
Current 1/8 is 7.96@85.5mph but I haven’t looked at trap RPM. Still getting used to the strip process. Used to circle track.
Old May 27, 2021 | 12:51 PM
Duh's Avatar
Duh
You need to figure what MPH and RPM you want/expecting to cross the finish line. Since you want to race both 1/4 and 1/8 4.10 will most likely work out well with a typical 455. If anything the 4.10 is not enough for 1/8. I would look at what the 1/4 mile combination is and use that gear. Since I don't know anything about your combo it's a guess.
Old May 28, 2021 | 07:20 PM
wr1970's Avatar
I think you are right Duh. Without knowing more about combo this is a guess. And most likely it should be okay.
Old May 29, 2021 | 07:44 AM
Jhucks03's Avatar
Thanks for the input. I have decided to stick with the 3.42s and keep my streetability since I drive this car every chance I get (have had it 20yrs, since high school). I will go with 4.10s when I can drop some more change on the motor.
Currently it’s:
’71 Cutlass (3,750 pounds)
fiberglass hood
455 swapped in
.030 369P pistons already in it when I found it at Pick-n-Pull
thumpr cam kit (springs, timing chain, etc)
‘68 Toro C heads (not ported that I know of, but were on motor)
torker intake
nice 750HP double pumper
hei ignition
flowtech headers
Single chamber off-brand mufflers turned out ahead of axle with cutouts installed just after collectors
th350 w/shift kit of some sort
10-inch “3,000” rpm stall Summit converter (gone over by Atlantic Coast Converters to up the quality some)
3.42 w/ welded spiders
went 7.962@85.57 1/8 mile (275/60-15 drag radials) with some left to gain, I’m sure
Old Jun 5, 2021 | 06:30 PM
69CSHC's Avatar
Very important.
Great story. Maybe she will be with you for the rest of your life or at least deep into your golden years. I managed 18 years with my first Old's.
Great performance !
Old Jun 5, 2021 | 07:19 PM
Rallye469's Avatar
I'd go 3.90's
Any more and you'll be floating valves for the 1/4
-peter
Old Jun 27, 2021 | 05:44 PM
Jhucks03's Avatar
Update:
Went a 7.85@86.5 mph with a 1.69 60’ today.
Blair
Aug 20, 2017 04:16 PM
Gary M
Sep 8, 2016 05:55 AM
TenMidgets
Nov 25, 2015 10:11 AM
quentinnw2
Nov 4, 2013 05:54 PM
72CUTTY
May 16, 2012 05:11 AM
