60’ improvement?
Old Jun 28, 2021 | 05:07 AM
Jhucks03's Avatar
60’ improvement?
How to improve 60’ time if your not spinning? More gear, less weight?
Old Jun 28, 2021 | 05:43 AM
Rallye469's Avatar
More powa baby!
Old Jun 28, 2021 | 06:24 AM
Jhucks03's Avatar
In progress. Have a set of ported heads and little bigger cam.
Was mostly curious if there is any need to worry about suspension stuff if I’m not spinning. Have been 1.69 @ 3,700 pounds on 275 drag radials.
Old Jun 28, 2021 | 06:53 AM
Rallye469's Avatar
If you're sure you're not spinning, then it's gears, convertor and power.
What are you using for each?
(and you could ALWAYS be thinking about cutting weight)
-peter
Old Jun 28, 2021 | 01:07 PM
coppercutlass's Avatar
Chevy budget Olds powered
Gear , converter , weight. I'm hitting 1.56 60 ft. Times with my 72 cutlass with a 350 olds . It only has a 3.90. I really need a 4.30 but it's all one fine dance. The right suspension parts and set up will work wonders. Along with a good torque converter.
Old Jun 28, 2021 | 01:48 PM
Jhucks03's Avatar
10-inch Summit “3,000” converter
3.42 gear (still drive it to work a good bit)
Old Jun 28, 2021 | 02:29 PM
I got a 4500 stall and still drive it on the highway around town. Regularly 30 to 50 miles or so on weekend drives.
My2nd 69 442
Apr 11, 2022 10:27 AM
4SPEED67
Feb 21, 2018 05:41 PM
Gary M
Sep 8, 2016 05:55 AM
TenMidgets
Nov 25, 2015 10:11 AM
quentinnw2
Nov 4, 2013 05:54 PM
