Quick rattle can question
Old Oct 10, 2016 | 01:50 PM
DewChugr's Avatar
Photoshop God
Is it ok to spray duplicolor sand able primer directly of their etch primer without sanding first?
Old Oct 10, 2016 | 02:39 PM
Tedd Thompson's Avatar
I can't see a reason why not other than you won't get as smooth a finish. Check the directions for the window of time needed so the first coat will be dry enough so as not to lift with the second coat.... Tedd
Old Oct 12, 2016 | 04:25 AM
Rocketowner's Avatar
X2 Tedd. I would suggest making sure the etch time was dried properly,and that depends on weather conditions and humidity. Larry
Old Oct 13, 2016 | 03:24 AM
chopolds's Avatar
Sanding is necessary, if the paint or primer you have on the piece has dried too long. Usually, if you have to wait overnight, you have to sand before continuing. Real paints (as opposed to spray bombs) will have instructions with flash time between coats, and recoat time. If you go past the recoat time, you have to sand. With cans, they might tell you, but I've found the information is not always accurate. Temperature, humidity and air flow also have influences over dry time, recoat time, etc., as well as how you apply the paint (film thickness, for one)
76CutlassSalon
Paint
Feb 24, 2016 10:01 AM
RustRocket
Paint
32
Sep 13, 2014 06:26 PM
HiCompOlds
Paint
Feb 5, 2012 06:02 AM
Nilsson
Jul 10, 2009 04:19 AM
Brian F
May 31, 2009 08:35 PM
