Need a little help
Old July 18th, 2013, 05:34 PM
71ray's Avatar
Need a little help
Hi, I have a 71 cutlass supreme with a 350, I just had a local shop install a new starter, accel plugs, msd 8mm wired and a Pro Form hei distributor about 2 weeks ago. My car ran fine for a weekend, put the family in it and went to a BBQ and when I arrived parked it let the family out and a buddy wanted to hear her growl so went to start it and nothing, power comes on but no nothing, tried it a couple of times and then saw the horn relay start to smoke and the post where there are about 4 wires on it with the bolt on it. Don't know much about mechanics but I am trying to trouble shoot my way threw this, does anybody have a idea what is happening and could a bad horn relay cause this? Thanks
71ray is offline
Old July 18th, 2013, 07:41 PM
It could have been a loose connection at the post. It also could be a bad connection at the starter causing that wire to get hot. That stud is where the wires branch from the main battery feed to the starter and then the alternator and the rest of the main power to the car.
oldcutlass is online now
Old July 18th, 2013, 07:44 PM
Well, then, time to start troubleshooting.
Start from scratch. What's your battery voltage? What is it when you (try to) crank?
Have you tried to jump the starter S terminal to the battery (+) terminal?
Have you checked your cables and wires for good, tight, clean connections?
Have you checked to be sure that the heavy (-) battery cable is connected to the engine block, and that the block is grounded to the body through a ground strap?
Have you considered sending it back to the garage that screwed it up in the first place?
MDchanic is offline
Old July 18th, 2013, 07:56 PM
All good arguments for doing it yourself and knowing what was done.
Allan R is offline
zak0331
May 5th, 2014 05:29 PM
Leadfoot
February 5th, 2014 03:58 PM
davepnola
October 12th, 2010 07:36 AM
tpawlik
August 5th, 2009 06:31 AM
henryk8398
Ninety-Eight
January 24th, 2009 07:49 AM
Quick Reply: Need a little help
