Need a little help
Need a little help
Hi, I have a 71 cutlass supreme with a 350, I just had a local shop install a new starter, accel plugs, msd 8mm wired and a Pro Form hei distributor about 2 weeks ago. My car ran fine for a weekend, put the family in it and went to a BBQ and when I arrived parked it let the family out and a buddy wanted to hear her growl so went to start it and nothing, power comes on but no nothing, tried it a couple of times and then saw the horn relay start to smoke and the post where there are about 4 wires on it with the bolt on it. Don't know much about mechanics but I am trying to trouble shoot my way threw this, does anybody have a idea what is happening and could a bad horn relay cause this? Thanks
It could have been a loose connection at the post. It also could be a bad connection at the starter causing that wire to get hot. That stud is where the wires branch from the main battery feed to the starter and then the alternator and the rest of the main power to the car.
Well, then, time to start troubleshooting.
Start from scratch. What's your battery voltage? What is it when you (try to) crank?
Have you tried to jump the starter S terminal to the battery (+) terminal?
Have you checked your cables and wires for good, tight, clean connections?
Have you checked to be sure that the heavy (-) battery cable is connected to the engine block, and that the block is grounded to the body through a ground strap?
Have you considered sending it back to the garage that screwed it up in the first place?
davepnola
October 12th, 2010 07:36 AM
henryk8398
Ninety-Eight
January 24th, 2009 07:49 AM
