New HEI distributor
New HEI distributor
Hi All;
I have a 1969 442 [with a 1976 455 engine]. I have rebuilt the engine...now putting it all back together. I want to be sure the new HEI distributor will work with the original tic-toc-tach. The link to the distributor I have is below. I know it has a "tach" connection on it...but is it compatible with my tach?
also...is there a way to test my tic-toc-tach to be sure it works? [it did not work with my old HEI distributor, so I'm not sure if the problem is in the tach or in the distributor.
http://www.ebay.com/itm/OLDS-HEI-DIS...ee31bc&vxp=mtr
I just upgraded from a 350 with original ignition toa 455 with HEI and the tic toc works fine. Just plug the tach wire into the tach connection on the HEI. Accel makes a slick littel plug in adapter so you can splice the wire then plug n play.
joepenoso
June 4th, 2014 01:56 PM
