New HEI distributor
Old Apr 17, 2014 | 09:58 AM
ctreutel's Avatar
New HEI distributor
Hi All;
I have a 1969 442 [with a 1976 455 engine]. I have rebuilt the engine...now putting it all back together. I want to be sure the new HEI distributor will work with the original tic-toc-tach. The link to the distributor I have is below. I know it has a "tach" connection on it...but is it compatible with my tach?
also...is there a way to test my tic-toc-tach to be sure it works? [it did not work with my old HEI distributor, so I'm not sure if the problem is in the tach or in the distributor.
http://www.ebay.com/itm/OLDS-HEI-DIS...ee31bc&vxp=mtr
Old Apr 17, 2014 | 03:55 PM
jag1886's Avatar
I would have to believe your tach is compatible, I put an HEI in my 65 and the original tach works the same as it did with points.
Old Apr 18, 2014 | 12:56 PM
joades's Avatar
ZATBAD 72
I just upgraded from a 350 with original ignition toa 455 with HEI and the tic toc works fine. Just plug the tach wire into the tach connection on the HEI. Accel makes a slick littel plug in adapter so you can splice the wire then plug n play.
Old Apr 18, 2014 | 02:02 PM
Octania's Avatar
Your tach may have the inline fuse holder feeding it, backside of dash. Easy to check and fix if blown.
joepenoso
Jun 4, 2014 01:56 PM
oldscruiser
Feb 15, 2011 12:44 AM
Oldsmobile Jo
May 30, 2010 07:58 AM
1964F85
Feb 21, 2010 05:25 PM
Frankenpez
Feb 8, 2009 07:38 PM
