Back again and my new project!!!
Im fast but not furious
Thanks for your compliments!!!!
So here are the updates from today:
Put the oil pump and screen together and mounted them...
Then ive bolted on the new Edelbrock intake....
After that ive cleaned the shop again....
So its the Trannys turn...:
Ive drained the fluid, unbolted the pan and i must say it looks really good, no metal pieces in it.
Then i replaced the kickdowncable, cooler lines, vacuum modulator and the tranny mount... tomorrow i will continue the work on the tranny ...
So here we go:
So here are the updates from Today....
Completed the steering linkage and bolted everything right.
I put on a new filter with gasket and pan on my TH 350...
Then i put on the oilpan on my 455 also the HV Water pump....
After that, sean(blukangoo) came over and brought me the slide hammer to pull the axle´s out (Thanks for the help, Sean!!!)
So thats all i got for Today....
Well i wish everybody Merry Christmas and some relaxing Holidays with your family!!!!!!!!!!!
Torsten
Torsten
I want to add:
I REALLY WANT TO THANK EVERYBODY WHO HELPED ME OUT, ANSWERED MY QUESTIONS AND ANYONE WHO TRIED TO HELP!!!!!!!!!!!!!!!!!!!
WITHOUT YOU GUYS & GALS, MY PROJECT WOULDNT EVEN TURNED OUT THAT WAY IT GOES!!!!!!!!!!!!!
YOUR KNOWLEDGE AND SKILL IS AWESOME, ITS GOOD TO KNOW THAT THERE ARE PRO´s OUTSIDE TO HELP SOMEBODY (even he is overseas
) OUT!!!!!
MAY GOD BLESS ALL OF YOUR FAMILYS AND FRIENDS
THANK YOU
WITH BEST REGARDS,
TORSTEN
) OUT!!!!!MAY GOD BLESS ALL OF YOUR FAMILYS AND FRIENDS
THANK YOU
WITH BEST REGARDS,
TORSTEN
So guys a lot of progress the last 2 days but i had no time to post
So here we go:
The axles were out; ive cleaned them and had to grind about 1mm in diameter from the axle plate where the wheels are mounted to, cause the rotor wont slide over them.....
after that i put on the spacer, Backing plate, tapped the axle shafts back in, and bolted everything together....
So here we go:
So back to the rear axle...
I pre installed the rear axle lines to measure everything for welding on the new brackets...
Got it, good, then i welded everything together, Dont look to close
Oh WoW, Thank you very much Jamesbo!!!!!
So today, i had to move from the car lift, cause someone had to chance the clutch from a 93 volkswagen...
ive bolted on the rims and tires from my buddys 73 camaro and rolled the frame outside
Thank god i bought a waterproof cover ..
I did some little "upgrades" on my 455 ... I LIKE IT, I LOVE IT...
So then the worst work on my cutty, i get rid of the tape from the wiring harness, but this was just the beginning.....
So that´s it !
Thanks guys
Torsten
So that´s it !
Thanks guys
Torsten
Sorry for late, guys....
Im stressed out the last couple of days....
So but a bit of progress i have to post....
Here we go:
Ged rid of the tape from the dash harness, i must say it looks pretty good...
Ive ordered 150 meters of different color wires, plugs and sockets, so i will do the engine harness complete new, by myself at first....
and i completed the rear axle brake lines....
Here we go:
Just Married!!!
The Tranny and ENgine have just been married!!!!!
with the driveshaft everything is complete.
After that ive bolted on my new Summit Starter and pre bent the tranny cooler lines.....
So then i deserved bad news...
The HV Water pump doesnt fit with the other pulleys....
I have to buy another one ....
Heres the new Starter, the coooler lines and the whole package
Regards,
Torsten
...Regards,
Torsten
Looking pretty good Torsten!
You have came a long way since the last time I was in the shop.
Sorry I can´t find more time to come and help.
Maybe that will change as soon as I am back at work and it gets a little warmer.
I almost got frostbite looking at the picture where the door was open and it was snowing like crazy.
Thanks sean!
Yeah its awful weather outside, its about 20 F and we had about 5inches of snow, not the real problem but very, very breezy, so i decided to do a little indoor work and make my electrician examination
The 2 front Wire Harnesses incl the headlights is totally complete, except for the Battery cables and a little TLC on the Horn Relay
That was an easy work and makes me feel better in the future
Here are the pictures:
Have a nice Weekend!!!
Regards Torsten
.That was an easy work and makes me feel better in the future
Regards Torsten
Ahh I forgot:
I didnt go with all the exact colors from the originals but "I" know where the cables have to go
And heres a good wiring diagram that i found on the web:
http://www.oldspower.com/images/tech.../71AbodyV8.jpg
Hope that helps!!!
Regards
Torsten
Hope that helps!!!
Regards
Torsten
I went by the shop today armed with a snow shovel.
First I cleared the snow at home, then I went and removed all the snow from the nice lady´s Driveway that is letting me park my truck in her garage.
The city came by and cleared the street and sprayed all the snow in front of our shop. I shoveled snow for about an hour and finally got in the shop.
I took a couple of pictures too.
In one of them you will see where my username comes from.
Greetz Sean
Greetz Sean
Thanks sean for clearing the shop from the snow!!!!
I moved the trash from the shop yesterday, damn, you could do this all day
So the rear harness is completed, except for the seperated fuse backup from the stop and flashing lights.....
I also replaced the backup lamp and license lamp cables ....
Tomorrow i will complete the 3 harnesses.....
In Germany the hazard lights has prior to the stop lights so i have to select the outer taillights as the "flashing lights" and the inner ones to stop lights
Also i have to fuse every light seperately
Additional the rear sidemarkers must not work, and the front just have to flash
This is so idiotic, but its Germany!?!?!
Good News i have for my Waterpump and Differential Gasket....
I received the parts today, correct waterpump in height and the correct O Type axle gasket!!!!!
For those, who cant find the right gasket for this "exclusive axle", you can see the Part number in the picture, i will attach.
Regards,
Torsten
Regards,
Torsten
So the updates for Today,
I bolted on the new poles on the pos and neg. battery cables. I didnt cut to length because i want to route the cables with enough room to clear the headers .....
Added the last cables to the harness and soldered the resistance to the vacuum switch cable (the switch on the intake manifold with 3 vacuum plugs?!?)
The rear light assemblies i fused seperately, one fuse for each Stop Light and one for each Flashing Light...
I decided to make the outer ones as the Flashing lights and the inner ones will work just as stop lights... I dont like that but it has to be that way..
Torsten
Torsten
After all the cables, i needed some different work, so i primed and painted my new Water pump in a semi gloss silver.....
And the new Audio Cables i will move with, into the rear harness.....
That s all for today
Regards
Torsten
Regards
Torsten
Progress of today:
Bolted on the new Waterpump, alternator and brackets, steering pump with brackets including the the pressure and return hoses, and attached the belts to them....
After that i installed the rear axle cover with "matching" gasket....
Also ive redone the ac harness which has some horrible routing
Then i blasted the horn relay and blower relay....
So thats all for today...
I hope you like it!!
Torsten
A little cosmetic again today...
I cleaned up the complete dash....
removed the emblems and switches and i also bolted on the new main light switch...
then i customized a templete for the wood inlay ....
after that ive cut out everything from the the new wood adhesive foil and pasted it on the dash...
Man, it looks awesome!!!!!
i cleaned the instrument lens, primed and painted it in a semi gloss silver ( i know its chrome original
After that i also put on the new foil on the lens ...
) .... After that i also put on the new foil on the lens ...
Then i received the work for monday
New Seatbrackets for my bench to bucket conversion...
Oil pressure switch, stop light switch, sidemarker sockets and door jamb switches....
After that i primed and painted the horn and blower relay...
Have fun watching!
Regards,
Torsten
Have fun watching!
Regards,
Torsten
dissasembled the arm rests with the ?painted? stainless trim...
I pollished the trim and completed everything with the new bases and pads...
i also cleaned and pollished the inner door handles
after that i did some work in our shop...
i started to clean up the floor pans ... puuh the angle grinder gets heavy after a hour...
the floor pans look like new, just wax
i welded on the new bucket seat brackets ..... sorry for the bad pics ... i will took new ones tomorrow...
