Back again and my new project!!!
#163
Thanks guys,
hehe, hmmm good question.... next!?!?
So not much progress the last 2 days.....
ive found some speakerthing or what has survived from it....
then i started to cut the firewall insulation pad....
where do you find the time.
#164
i wanted to bolt in the ac box, to see if it fits....
and as you can see..... the breather is too tall, ive tried the angle breather from the 350 but this wont fit, also....
what shall i do....????
That s*cks...
That s*cks...
#165
after that we had to move my buddys rear axle and leaf springs to the shop....
bolted the diff cover, and filled it with oil
then i pressed out his old u joints from the driveshaft and put the new ones in....
#167
then i had to straigten the bumper braces?!? cleaned, primed and painted them....
Sorry for the smaller pictures, batterys were empty so i had to shoot with my mobile
so thats it for now...
Regards,
Torsten
Regards,
Torsten
#168
...and me, sitting at home with nothing to do and nobody gives me a ring.
That would have been a perfect reason to get out of the house.
Tomorrow I will probably come by after we check out the new apartment for my son to put 1400 watts in my Pickup and am glad to see that the lift is finally free.
Can´t wait to check out your progress in person.
#169
Hi guys!
@Blukangoo: i thought you were check out the flat and move some furniture
So the last couple of days we´ve done some chebby work again....
We installed the leafsprings, shakel kit, rear axle and the driveshaft into the camaro....
#171
then today ive started to strip down the old paint to bare metal....
I began with the drivers fender......
Here are the first pictures, were you can see the original blue paint....
#172
Here the 90% finished fender after approximately 3,5 hours.....
You can see the sheet that was welded in the lower section..... it wasnt from a pro....
I hope you like it....
Regards,
Torsten
Regards,
Torsten
#174
If I find the time I will come over and help you get that blue paint off.
I thought I would learn how to do it on yours before I do it to mine.
#175
He will be moving up there in May. Thats when we will be moving the furniture.
Nah, its not as hard as i thought first.....
#181
Haha,
Thanks pat,
thats the problem; i just can`t cut off my hand...
how will i complete this cutie?????
So i think i have to use the ones ive bought
Thanks pat,
#183
Dang it's always the little things that get in the way.
Great looking job, She'll be pretty when done
Torsten
#184
I want to post in this tread so i will get the email about new posts here. Should be a great car when your done! My vote on the wheels is for torque thrust for obvious reasons.(got them on mine). Good luck to you!
#185
today i started stripping the hood....
there are at least 3 pounds of bondo on it .....
here the first pictures.....
any thoughts on the stripes???
Yeah i like them, but the SS1`s won the race...... they are unbeatable
Cant wait to see them in person
Regards,
Torsten
Regards,
Torsten
#187
Hi,
Yes you can!!!
Yes i pulled the dash and everything.....
The Front windshield is cracked, my painter will shoot this thing out and put in the new one ive ordered ...
The rear glass have to stay in place, its in good shape and ive heard about bad things when removing it, it will crack in most cases...
Also, it is very expensive... Keep in mind, we here are in Germany
Torsten
Yes you can!!!
Torsten
#188
So today, ive completed cleaning the hood....
also i unbolted the drivers door, so that i can start early tomorrow...
My deadline for the whole body is friday..... Lets see how it works....
Greetings
Torsten
Greetings
Torsten
#193
Thanks 71csvert,
So today ive finished cleaning the big surfaces like roof and rear quarter panel....
Then ive rolled the roof with rust converter called FERTAN....
This stuff is awesome...
I believe there was an vinyl top on the car and it has rusted beneath...
Also my new windshield has arrived...
Tomorrow i have to clean some small pieces on the passengers Fender, the door jambs section, Rocker panels (1 left) and the trunk section....
On Wednesday i want to weld in some sheets where i have to
and hopefully on Thursday we have to move the car to the paint shop....
Torsten
Torsten
#194
So today
i had to do some service to my daily driver so not much progress on my cutty....
just did some work around the rear window the trunk section and the second rocker panel....
Its just the small things that costs time... i believe all of you guys know best....
The roof completely turned into black, means the rust converter has worked, it gave the metal some more strength... dont know how this thing makes it- maybe magic
Here the pictures..:
Torsten
Torsten
#195
Hi,
today ive completed cleaning the door jambs and the trunk section...
I`ve tried every tool i have to clean these incredible shapes... unbelievable
at least 2 hours of scraping off the bondo/chassis adhesive on the lower trunk section.... damn this stuff is.... grrrrrrrrrr
But now its done.... puuuh
i have to leave some small work for the painter.....
here the pics.:
here the pics.:
#196
and the rest of it ....
Tomorrow some small pieces on one fender, then im completely done...
Ive decided that the painter does the rest of welding... its not that much.... our welding machine is in another shop
Also we could move this beauty to the painter if everything works...
Torsten
Torsten
#200
Thanks pat,
i just have a couple of days left to work on this project....
My deadline was!!!! end of may.....
I will never pass that...
My next working place is the netherlands /GOUDA - say cheeeeseee lol
i will leave home end of next week
I dont know for how long and whats next............. puuuuhhh
May the force be with me
