1970 Street/Drag Project
Old Jan 8, 2024 | 05:46 PM
  #161
gear head's Avatar
Thanks guys!
The upper coilover mounts are burned in along with a couple changes in the front end. I need to get some 1/2" rod ends to make a couple dummy shocks, then I'll give it an initial alignment and get a new weight to see how much that changed. In a couple weeks I should have the pieces in hand to start the engine mock up.
Old Jan 8, 2024 | 06:39 PM
  #162
Eddie Hansen's Avatar
Slick!!!
You remind of this guy back in the early 80s his name was Arne kinarchild (spelling) A&k speed on Long Island ( Suffolk county) he raced a 70 1/2 Camaro big block , well every seam every casting flash everything was surgically cleaned and prepped his motor looked like billet instead of cast etc etc , crazy mad skills my friend just breath taking,
oh back in the day Arne could wind a big block Chevy to 9k plus lol it’s a unique sound
Old Jan 9, 2024 | 01:41 AM
  #163
fleming442's Avatar
Looking good, man. Sick Week is coming!
Old Jan 9, 2024 | 10:59 AM
  #164
oldsmoboogie's Avatar
Awesome work! What rack and pinion are you using?
Old Jan 10, 2024 | 05:30 AM
  #165
gear head's Avatar
Thank you Eddie, N/A big blocks spinning 9k sound badass.
Old Jan 10, 2024 | 05:31 AM
  #166
gear head's Avatar
Damn, I wish I could make it, Are you going?
Old Jan 10, 2024 | 05:39 AM
  #167
gear head's Avatar
Thanks man!
Unless the oil pan says no way, I'm going to try to stay with a manual gearbox. I have serios doubts that i will be able to use the gearbox and centerlink setup due to the fact that I'm going to try to make provisions to remove the oil pan while the engine is in the car. This will likely involve some kind of removable engine crossmember. If I do end up going with a rack, I'll probably source it from TRZ.
Old Jan 10, 2024 | 06:16 AM
  #168
fleming442's Avatar
Yes, but the 442's heart is questionable and is going under the knife. Back-up plan B is to bomb around Sick Ward in the Suburban. Back-up plan C is the S4, but I will definitely be there whether racing or spectating.
Old Jan 10, 2024 | 07:03 AM
  #169
rfpowerdude's Avatar
Man, that is going to be a great car. And, Sick Week here near me is cool too. Looking forward to seeing this car all put together!
Old Jan 10, 2024 | 07:22 AM
  #170
gear head's Avatar
I hope it's nothing too serious and the 442 can make it. I can see sick ward being a good time....Hang out, drink some beers, see some cool cars and watch everybody blow their **** up.
Old Jan 10, 2024 | 07:24 AM
  #171
gear head's Avatar
Thanks man! I'm getting there, still many thousands of dollars to go.
Old Jan 10, 2024 | 02:38 PM
  #172
69455's Avatar
Are your coil over shock mounts homemade or a kit option somewhere ?
Old Jan 10, 2024 | 04:51 PM
  #173
gear head's Avatar
I picked up the mounts from Global west, very nicely built but, their directions are flawed. TRZ also sells a cup that welds in in the same area that is a bit cheaper but, I'm not a big fan of the post top mount.
Old Jan 10, 2024 | 07:02 PM
  #174
75 W-30 H/O's Avatar
Phew, finally got caught up. This is so much better than anything on Mototrend TV. Your work is incredible!
Old Feb 4, 2024 | 04:48 PM
  #175
gear head's Avatar
Thank you for the compliment!
Old Feb 4, 2024 | 04:57 PM
  #176
gear head's Avatar
Dummy shocks are made/installed, set the car back to ride height then set the initial alignment...everything at zero aside from caster at 4*.
New weight of 1712lbs
CPP arms changed to Autofab
Factory discs to Baer ss+4
Added front coilover mounts
Added rear fiberglass bumper and factory brackets
And a bunch of engine crap building up....time to start on the blower bracket.
Old Feb 8, 2024 | 06:21 PM
  #177
oldsfromyell's Avatar
Awesome job on your project. Great progress being made on it for sure.
Old Feb 9, 2024 | 03:16 AM
  #178
fleming442's Avatar
I'm listening....... whatcha doin'?
Old Feb 9, 2024 | 08:29 AM
  #179
gear head's Avatar
Thanks man!
Old Feb 9, 2024 | 08:46 AM
  #180
gear head's Avatar
I'm doing a reverse rotation(forward facing) D1-X Procharger. I think I will take a page out of Trimbles book and do the mock up out of MDF and transfer that to aluminum. While I'm at it, I'll get all the accessory drives completed as well..vacuum pump and alternator. Most of the drive parts should be here by the end of next week but, Still waiting on the trigger wheel that is backordered. Once I have all the pulleys, Tim at Star Machine wants me to send them to him to get everything machined to interlock together and he will send them back with the vacuum pump parts. Should be tons o fun.
Old Feb 9, 2024 | 08:58 AM
  #181
fleming442's Avatar
T I T S !!!!!
Sounds like some serious stuff.
Old Feb 11, 2024 | 09:16 AM
  #182
gear head's Avatar
Just serious enough to touch a four digit power level.
Old Feb 11, 2024 | 12:08 PM
  #183
I probably missed it or forgot, are you doing a Rocket Racing block?
Old Feb 11, 2024 | 01:28 PM
  #184
Battenrunner's Avatar
Definitely keep up the details when you get to the design and fab/machine work for all the brackets and pulley systems.
Thanks again for sharing your build.
An Engine parts and build list would be much appreciated as well.
Old Feb 12, 2024 | 09:12 AM
  #185
gear head's Avatar
It will be a 434ci diesel block.
Old Feb 12, 2024 | 09:26 AM
  #186
gear head's Avatar
No problem, since there is very little to no info on supercharging an Olds, I will try to be as detailed as possible with the pulley stack and blower drive/brackets. Once I have everything in place and in alignment, I will post all the part numbers and any modifications to the pulleys. I will post all of that in here and make a dedicated thread in the racing section so people won't have to dig through this thread to find it.
One of the larger hurdles will probably be the cooling system packaging, specifically the radiator. Due to the location of the blower, i will have to do a radiator mounted water pump and will plumb the system for reverse cooling.
Old Feb 12, 2024 | 09:38 AM
  #187
Oh, sweet! Similar to Paul Tester's original 434 diesel? But with the supercharger to push the capability of the diesel block? Should be badass.
Who is building/machining it?
Old Feb 13, 2024 | 06:58 AM
  #188
gear head's Avatar
Really, there are only two shops in the area that I trust for machine/assembly/Dyno....Westside Machine in Boise ID and Fastlane Machine in Orem UT. Both are more than capable but, I think Fastlane is a bit more savvy with the Oldsmobile platform. I thought about sending everything to Trovato but, it just doesn't make sense to ship across the country when these two shops are so convenient.
The heads and intake will probably be sent to Knowltons for porting and injector bungs.
Old Feb 13, 2024 | 07:07 AM
  #189
Sounds like a good plan. Here in Florida, there is only one guy I trust now.
Would be nice to be near Bill T. also!
Old Feb 13, 2024 | 01:18 PM
  #190
69455's Avatar
What brand and or type of shock( coil over) you going to run.
Old Feb 14, 2024 | 07:00 AM
  #191
gear head's Avatar
I am going to run Menscer twin tube coilovers. These will be one of the very last things I purchase for the car.
Old Feb 21, 2024 | 06:22 PM
  #192
gear head's Avatar
Taking care of loose ends while I wait for the trigger wheel..
Fuel cell straps are bent and installed. I placed oil/fuel resistant rubber mat under the cell and straps to help protect the aluminum from damage. The steering column and shaft are pretty much done..just need to weld the dash bar bracket in and paint. Don't pay any mind to the shaft/u-joint bolts....proper AN fasteners are on the way.
Old Feb 22, 2024 | 05:51 PM
  #193
dc2x4drvr's Avatar
Very nice job, I like your style!
Old Mar 18, 2024 | 04:29 PM
  #194
gear head's Avatar
^^^Thanks man!
Hardware in the doors and proper fasteners in the steering shaft.
Old Mar 18, 2024 | 04:42 PM
  #195
gear head's Avatar
Here's the starting point for the blower bracket.
Crankshaft pulley stack up:
ATI damper #917840
Holley trigger wheel #556-180
Jones 5" alt. pulley #DH-3102-C-5-BB
Vortech 7.8" 10 rib blower pulley #4MA018-061
The alternator pulley and blower pulley are being sent to Star machine to get married together and will be sent back with the vac. pump.
Old Mar 18, 2024 | 06:02 PM
  #196
fleming442's Avatar
This is a juicy one! Let's GOOOOO!
Old Mar 18, 2024 | 06:20 PM
  #197
Looking great!
By the way, ATI will install magnetic trigger points in your damper for a minimal fee, if you need the extra room at the front of the crank.
Old Mar 19, 2024 | 05:14 PM
  #198
gear head's Avatar
Looking great!
I almost got that addition when I ordered the damper. The only reason I didn't was that I wasn't sure if the blower pulley was going to be directly on the damper, the smaller diameter for the trigger wouldn't have worked with the larger diameter pulley against it. It does work in the above scenario so, it could be an option now, it would require the alternator pulley to be machined though.
Old Mar 19, 2024 | 05:25 PM
  #199
gear head's Avatar
this is a juicy one! Let's gooooo!
Old Mar 20, 2024 | 12:36 PM
  #200
Ah, I see your point if there wasn’t a gap for the alternator pulley originally.
I was wondering about the crank snout loading and keeping everything as tight as possible to the nose of the crank to keep strain and chance for breakage lower.
What crank are you running/planning on?
I may eventually have ATI install the magnets on our damper at some point, if we have any issues or signal discrepancies/errors with the Holley/MSD dual-sync distributor. I know the signal isn’t as accurate from the distributor as it would be from the crank trigger/damper and a cam signal from the cam gear attached to the camshaft….but it works at our current power level.
