1970 Street/Drag Project
Old Sep 20, 2016 | 11:47 AM
  #41
Eddie Hansen's Avatar
some awesome welding skills my friend
Old Sep 21, 2016 | 07:16 AM
  #42
gear head's Avatar
Thank you very much!
Old Oct 2, 2016 | 09:35 AM
  #43
gear head's Avatar
After welding in the last couple patches and some bumping and shrinking, I’m going to call this panel done. It’s not perfect but , It’s the best I can do at this time…Either way, the car will have about 50lbs less bondo in this corner.
Rinse and repeat for the left side…
Old Oct 17, 2016 | 04:12 PM
  #44
w30442's Avatar
Nice workmanship. Project is coming along pretty good. What rear discs and brakes did you end up using that fit your 15 inch wheels
Thanks Glen
My vote is for Matador Red but that's probably bias
Old Oct 17, 2016 | 06:27 PM
  #45
gear head's Avatar
Thank You, Glen.
They are basically factory rear discs..
Speedway rotors - #910-31039
D-154 calipers (w/parking brake) - #91031046
Hawk HPS pads - #HB 119F.594
Self made 0.250" thick caliper brackets
Although I do really like the Matador Red, The car will be blacked out completely and painted in a Mitsubishi Tarmac Black (x42 code) with the 442 stripes ghosted in....
Old Oct 18, 2016 | 07:59 AM
  #46
TripDeuces's Avatar
That is nice stuff, great job.
Old Oct 18, 2016 | 11:34 AM
  #47
gear head's Avatar
Thanks man, much more goodness to come. The sheet metal wheel tubs are enroute. After I install them, I can cut out the trunk floor and tub it for the fuel cell and battery. Getting closer to building the cage!
Old Jan 8, 2017 | 06:18 PM
  #48
gear head's Avatar
Not much of an update but, I did get some time to play with the old turd through the holidays. The left rear quarter panel is done, wheel tubs are fitted and ready to weld in and I got started on the fuel cell mounting. As always, questions, comments and constructive criticism are welcome.
Old Jan 8, 2017 | 08:08 PM
  #49
TripDeuces's Avatar
That's nice work.
Old Jan 9, 2017 | 06:56 AM
  #50
ah64pilot's Avatar
Wish I had your patience and skill. Very nice work indeed. Can't wait to see it finished!
Old Jan 9, 2017 | 02:05 PM
  #51
gear head's Avatar
Thanks guys, I appreciate it.
I somehow ended up with the day off today, so I took advantage of it and built the frame support for the fuel cell. As per NHRA rules I still need to make a sheet metal enclosure for the exposed part of the cell under the vehicle. I am also going to notch the trunk floor 1" forward of the cell for the battery box.
Old Jan 9, 2017 | 04:00 PM
  #52
Stefano's Avatar
Nice skills, you seem to know your way around GM "A" bodys that is for certain.
Old Jun 25, 2017 | 06:35 PM
  #53
gear head's Avatar
Just a small update for those following my slow progress on the ol' turd...
The trunk area is complete with all unnecessary metal removed, patch repair and sheet metal enclosure for the fuel cell welded in place.
I also got started on the A- pillars..
And the work continues....
Old Jun 25, 2017 | 07:00 PM
  #54
Very nice work.
Old Jun 25, 2017 | 07:11 PM
  #55
wr1970's Avatar
Wow i just wished you were my neighbor! Good job on your project.
Old Jun 25, 2017 | 07:22 PM
  #56
gear head's Avatar
Thanks guys.
I got the day off tomorrow so, I can get the left side A-pillar done. After that I'll either tackle the lower windshield channel or start shaving the drip rails.
On a side note, I still need to track down the rear tulip panel and a left door...lol, I hate body work.
Old Jun 26, 2017 | 07:55 AM
  #57
wr1970's Avatar
Originally Posted by gear head
Thanks guys.
I got the day off tomorrow so, I can get the right side A-pillar done. After that I'll either tackle the lower windshield channel or start shaving the drip rails.
What is a tulip panel?
Old Jun 26, 2017 | 06:05 PM
  #58
gear head's Avatar
It's the half round panel at the base of the rear glass. It's bad enough that I would rather replace it than repair the existing panel.
Old Jun 26, 2017 | 06:10 PM
  #59
gear head's Avatar
Left side A-pillar done...
Old Jun 27, 2017 | 02:55 AM
  #60
wr1970's Avatar
One word for your welding skill and fab skills.(awsome}
Old Jun 27, 2017 | 06:46 PM
  #61
gear head's Avatar
Thank you, welding/fabrication and wiring are my favorite parts of building a car. I'm looking forward to more fun Parts of the project... not so much on the mindless body work.
Old Jun 28, 2017 | 04:57 PM
  #62
jfb's Avatar
jfb
hey congrats just stay diligent on the bodywork not everybody is cut out for it. I like your idea of a street strip machine it is what I do too. keep the body stock looking with some things hidden and use factory parts where you can they do work trust me but heavy duty too. with the engine trans rear suspension and brakes make sure it is balanced and matched for use. I would also think everything through along all areas like dialing back ignition lead to run decent gas even on bad days. good luck that's the way it used to be but streetable at the same time and faster with a slick change and maybe a shot of nos when needed for real competition. it will be worth it in the end and it will be a guaranteed modern day bad *** if balanced and thought through.
Old Jun 28, 2017 | 08:14 PM
  #63
gear head's Avatar
Thanks for the input, it is appreciated...
It's not that I'm incapable of doing the bodywork, I just don't like to do it. The flip side of that coin is that I trust no one to do it so, in this instance, I am my own worst enemy. I am actually using very little as far as the factory parts go, just the dash a few interior panels and the glass...everything else will be sold or scrapped. I have been building, modifying and tuning cars my entire life and have also done a 15 year stint with a pro road race team so planning a build is nothing new to me.
I have not been very forthcoming about the plan or details for this car, so here it is in a nutshell...
The main goal for the car is to compete competitively at drag week in the Street Machine Eliminator class. After that I will mainly hit PSCA events until I can get my *** moved back to PA. This will mainly be a race car with some street manners, however, it will not see all that much driving. Some of the details for the car are as follows.
Engine: 440ci Diesel based small block
Billet crank
GRP aluminium rods
Diamond pistons
Rocket Racing heads
Speedtech Nitrous system
The engine will be capable of a reliable 900-1000hp but I will only be running enough to put the car in the high 9's leaving myself plenty of headroom to grow.
Transmission/Driveline: JW competition TH-400 with Ultra-bell.
Carbon fiber driveshaft
Coan torque converter
Chevy 12 bolt with 35 spline strange axles, spool and
9" housing ends
Trans and ring and pinion gearing will be decided after the engine dyno's.
Interior: Race Tech seats
12 pt cage
AIM digital datalogging dash
Exterior: Fiberglass front/rear bumpers, deck lid and w25 hood with raised
scoops
Shaved drip rails
Mitsubishi tarmac black paint with the 442 stripes ghosted in. The car will be completely blacked out.
Obviously there are more details...damn, I think this is the longest post I have ever made on any forum.
Old Jun 30, 2017 | 01:15 PM
  #64
wr1970's Avatar
I would think with your combo you will be at a high nine without nitrous system with low nine. A lot will be the weight factor. I will be tagging along on this thread. Have you seen my tube chassis car in my album? It is Black.
Old Jun 30, 2017 | 03:22 PM
  #65
gear head's Avatar
I'm looking to have the car in the 10's without the nitrous and I'll just spray as much as needed to hit high 9's. The Speed Tech kit will flow a 500 shot without breaking a sweat and the cage will be certified to 8.50 so that leaves a bunch of room to grow if I ever decide to do so. Obviously, I would have to make a few upgrades to run that quick. The weight factor for the finished car is still unknown, I haven't even scaled the bare car yet.
I think I did see that at one time, looked like a nice car. How's the progress going with it?
Old Jun 30, 2017 | 03:29 PM
  #66
gear head's Avatar
Made it home early from work today and started shaving. The only reason I'm doing this is because the rails were completely rotted out and I didn't want to go through all the work to repair them properly.
Unfortunately, the damage goes a bit farther than just the drip rail on the right side.
Hopefully I can get both sides complete this weekend. Enough with the car for now, it's time to focus on beer...
Old Jun 30, 2017 | 08:00 PM
  #67
wr1970's Avatar
I am on hold for eight months waiting on the 62 social security. I have no job. I plan on having the car at the track in fall of 2018 for a shake down run. The motor should get me in the tens. The other motor i have planned to put in it will not be ready. The whole front end is fiberglass and both doors, back bumper,front bumper. The front end is set up to tilt.
Old Jul 1, 2017 | 12:26 PM
  #68
Gerald Nickels's Avatar
Not sure why you didn't put fiberglass quarters on it to save weight. But it looks great. Next time call me in Calif. for a rust free car I can find them here. I should talk my 65 Cutlass has rust around windows but a Or. car.
Old Jul 1, 2017 | 02:30 PM
  #69
gear head's Avatar
Nice, there's never enough Oldsmobiles at the track. Can't wait to see it done.
Old Jul 1, 2017 | 02:39 PM
  #70
gear head's Avatar
Thanks man.
The thought of glass quarters did cross my mind but, I just wasn't sure about the longevity/quality of the bonding and didn't want to take a chance on future repairs after I dump a wad on getting it painted. I may take you up on that offer...my youngest daughter is really into wagons and loves the '70 Vista, I may build her one when she graduates from Dartmouth in a couple years. Oldsmobiles and olds parts for that matter are very scarce here in Utah.
Old Jul 5, 2017 | 06:10 AM
  #71
jfb's Avatar
jfb
I agree with all of you but I built mine according to old super stock rules and lightened. I like the stock and beautiful but fast approach. The idea of a fast and stock looking musclecar always struck me hard.
Old Jul 8, 2017 | 06:11 AM
  #72
gear head's Avatar
Honestly, that was the original plan for the car. The person who I had look over it for me before purchasing did a **** poor job of reporting the condition back to me so, upon delivery and looking it over with my own eyes, that ship set sail quickly. I don't blame anybody but myself for not flying out and looking at it, however if I ever see that person, he will get a kick square in the *****. I could bitch all I want but that won't change anything and I'm completely over it. The only saving grace is that I didn't over pay for the car and it will be done proper.
Old Jul 9, 2017 | 02:23 PM
  #73
gear head's Avatar
Well, I finished the right side today. I don't think it turned out too terrible for such a tedious task. The left side should go much faster since I won't have to do any extra repair.
So far so good with the pictures still working...
Old Jul 15, 2017 | 03:12 PM
  #74
gear head's Avatar
Lol, I guess I spoke too soon....oh well.
Old Jul 15, 2017 | 04:36 PM
  #75
wr1970's Avatar
Just use your phone to make pictures and then send to your email. Then you can upload post them here in a thread or in a album. That is what i do.
Old Jul 15, 2017 | 05:34 PM
  #76
gear head's Avatar
I can upload straight from my phone, I'm just not enthused to go through and figure out which pictures go where and re-uploaded everything. Maybe one day I'll get ambitious enough to do that and bring this thread back to life...
Old Apr 2, 2019 | 01:25 PM
  #77
gear head's Avatar
It's time to bring this thing back to life. pictures are re-loaded
Old Apr 5, 2019 | 02:25 PM
  #78
gear head's Avatar
Since we left off I really haven't done much with this thing but, we're back at it now.
Left drip rail shaved.
Now lets dive down this rabbit hole...Just a couple more small repairs and I can weld in the replacement cowl.
Sub-structure repair.
Old Apr 7, 2019 | 02:57 PM
  #79
gear head's Avatar
Not a perfect panel but, it's better than I had...err didn't have.
Anyways, happy national beer day. Cheers gentleman!
Old Apr 8, 2019 | 05:41 AM
  #80
VORTECPRO's Avatar
Nice work!
